cam specs, springs needed...etc
Old Jul 8, 2004 | 08:09 PM
teke184's Avatar
what is the stock lift on the ls1 cam (99)? i think it is around .520"
i'm thinking of upgrading to 1.8 rockers, possibly 1.85s. will a spring that handles .600" lift be sufficient? or do i need .650"?
Old Jul 8, 2004 | 11:17 PM
CrippleFightin's Avatar
I think the 01+ are like .497 lift and the 98-00 are something like .503 or somewhere close. If you plan to get a cam sometime you might not want the 1.8 or 1.85. Most of the cams I see are fast ramp cams and the bigger ratio rocker arms dont work well with then i guess. (just going by what i was told before buying my cam)
I dont think you will need a spring that handles .650 as a 1.85 rocker arm wont make the lift that high. A .600 spring will work.
Old Jul 9, 2004 | 06:30 AM
teke184's Avatar
yeah i know about the problems with cam selection. but if i do a cam there are quite a few that specifically state they are compatable with the higher ratio rockers.
thanks for the info
DirtyDaveW
Mar 15, 2015 07:01 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
