F/s Powerglide Trans
Old Jul 8, 2004 | 06:58 PM
bfly's Avatar
unit is made by transmission specialties
Pro Line 6000 Lock-up System comes with all accessories
This Trans is good up to 2000 HP
Transmission
9310 Alloy Gears
9310 Alloy Pins
4340 Forged steel Output w/ New Carrier
4340 Ring gear
Vasco Input Shaft
SFI Approved Case
2 qt. Extra Capacity Pan
Dual Ring Servo Piston
Rollerized Tail Housing
Teflon Sealing Rings
Quick Disconnect Cooler Fittings
Super 8 Lock-up converter
Spacer kit
Dowel Pins
Mounting Clamp
Timer Base
Timer
CO2 Kit
W.O.T Switch
AIr Cylinder
Relay
This set up has 8 pass on it unit was in a 7,sec car track only car this is a chevy trans bolts right up.
paid new $8000 asking $4500 OBO.
bfly121@comcast.net
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
force10
Aug 10, 2015 08:30 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
