Differences b/w '94 and '96/7 Z28 wiring harness
Old Jul 8, 2004 | 04:26 PM
tamatt27's Avatar
I'm doing an LT1 swap into my '88 T/A 305 TBI auto. I'm researching the wiring aspect of it, and I need to know if the '94 engine and underhood wiring are similar to the '96/7 wiring? I don't have a service manual, and I'd be using SI. But SI only has indepth diagrams starting in '96/7 I think. You GM tech's know what I'm talking about.
Old Jul 9, 2004 | 10:35 PM
bunker's Avatar
I belive just the extra wire for the crank position sensor & the fuse box inside the car uses the smaller fuses instead of the traditional ones.
Old Jul 9, 2004 | 10:58 PM
Things I can think of that are added on 96-97s:
crank sensor (as mentioned)
rear O2 sensors
EVAP vacuum switch
If you use an OBD-I PCM, leaving these disconnected will never be noticed.
cmdeshon
Jan 4, 2015 11:15 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
$hawn
Aug 3, 2002 04:59 AM
CobraEatr
Jul 23, 2002 06:32 PM
