Vortech ... loosing boost?
Old Jun 27, 2004 | 08:49 PM
[JFS]'s Avatar
Within the vacuume lines, PVC system, etc ... where have others found boost leaking out? I went back though the vortech install docs but it does not mention additonal check valves.
Where are common leak points? Additional air check valves being used?
Old Jun 27, 2004 | 10:04 PM
Highlander's Avatar
The most common leak point is incorrect installation of the bypass valve.
Old Jun 28, 2004 | 08:32 AM
stealth2's Avatar
Loose connections between the blower piping and after/intercooler
How much pressure drop from discharge to intake?
Mikes 1994 z28
Oct 10, 2015 07:55 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
