engine assembly question regarding rods
Old Jun 18, 2004 | 09:25 PM
SMOKNZ's Avatar
When looking at the cap of the rod where the bearing rides, one side flares out farther than the other. My question is do the larger flares go to the outside of the crank journal, or do they butt between the rods. I figured I would ask now when it's easy to change around. I would have looked at the old rods and pistons, but they are now disassembled. Look at the pic enclosed here : http://www.bytehead.com/~dunk/6-18-04.html
Is this in right? or backwards. I made all the rods go the same way on the pistons, I have floating pins, so it would be easy to reverse if needed.
Bill
Old Jun 18, 2004 | 09:35 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
That is correct. The chamfered side of the bearing will face the outside of the journal.
Old Jun 18, 2004 | 09:37 PM
SMOKNZ's Avatar
Thanks Jim!
Bill
Old Jun 25, 2004 | 11:01 PM
94bird's Avatar
Re: engine assembly question regarding rods
[/B]
This is the statement that worries me. If your rods are asymmetrical, as your picture shows, then when you build your piston/rod assys you will build a right and a left bank set (4 each). Did you do this? Your statement above makes it sound like you didn't.
A piston will have some kind of mark on it (many times an arrow or dot on the crown) to point to the front of the engine. This is critical since the piston pin will be offset and it should only be offset to one side. If it's reversed the piston will rock in the bore at the wrong time and will then likely make noises you won't like.
Old Jun 26, 2004 | 03:16 AM
SMOKNZ's Avatar
Re: Re: engine assembly question regarding rods
It shouldn't worry you It worked out fine. Yes the pistons have markings on them, little arrows that point up. The pistons and rods were right.
oldschool
Feb 9, 2016 09:21 PM
Hurin
Dec 13, 2014 07:38 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
squirrels
Jul 13, 2002 01:58 AM
