WTB: Sway Bars and Wonder Bar
Old Jun 13, 2004 | 11:46 PM
firebirdjosh's Avatar
I need any rear sway bar, a 32mm front sway bar, and a wonder bar for a 3rd gen. Post what you have.
Old Jun 14, 2004 | 12:21 AM
JSK333's Avatar
I have the stock bars and endlinks/bushings from my '95 Z28.
Old Jun 14, 2004 | 01:49 PM
dregsz's Avatar
I have the 19mm rear bar, 32 mm front bar, Poly D bushings, and poly endlinks (I need to make sure on the front endlink, definitly on the rear) for $120 plus shipping
Evan
Old Jun 14, 2004 | 02:31 PM
tweaked96z28's Avatar
wonder bar? panhard rod? if so I have a factory panhard rod for 10 plus shipping
Old Jun 14, 2004 | 05:14 PM
pb1995's Avatar
I have 1LE sway bars and poly bushings off of my 95 TA. 100+shipping.
Old Jun 14, 2004 | 05:42 PM
dregsz's Avatar
32mm/19mm is the 1LE size
I'll match the $100, split the shipping, and I offered first
So There
Old Jun 15, 2004 | 09:05 AM
pb1995's Avatar
It may be the same size, but 1LE are hollow and are made from better material to have the same strength as the heavy solid ones.
Old Jun 15, 2004 | 11:16 AM
Ok, in the 3rd gen tech forum I was told I have a 16mm front and no rear sway bar. I looked under and the front looks about 32mm and the rear is 16mm. I was told 32 in the rear would make it too stiff. I want to get some bushings first and a wonder bar.
Old Jun 15, 2004 | 11:20 AM
pb1995's Avatar
If the rear is 16 then the front is probably 28 or 29, that should be stock. Poly bushings will help, but if your going to do the work might as well do the bar too.
Old Jun 16, 2004 | 07:46 PM
I decided to keep my rear, so I am either getting a 32mm sway bar or a wonder bar, whichever best offer comes up first.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Aug 5, 2015 08:35 AM
SpeedJunkee
Jul 19, 2015 09:06 PM
