New Canfield LT1 heads
Old May 27, 2004 | 09:52 PM
OZ DREAMER's Avatar
NEW Canfield LT1 heads that were never released for public sale w/220 intake runners , 58cc chambers , stainless 2.08 in. 1.60 ex. , Comp springs good to .600 lift , set up to run center bolt or primeter bolt valve covers , they use a Fel Pro 1206 In. (mod to fit ) and a 1406 Ex. must use a .150 offsetIn. rocker (Jegs sells a whole set for $219) , ARP 7/16 studs and hardend guide plates go with them . Flow sheets are below . $1500 shipped obo
Scott
These HAVE to Go, somebody needs a set of heads for that 383 or 396...anybody?
Old May 27, 2004 | 10:01 PM
TransAm396's Avatar
hey...with a cc306 cam..what kinda power do you think id make on a stock block 93 6 speed t/a?
Old May 27, 2004 | 10:15 PM
OZ DREAMER's Avatar
mail sent
Old May 30, 2004 | 09:24 AM
OZ DREAMER's Avatar
T T T
come on people these are a lot cheaper then AFR's
Old May 30, 2004 | 12:38 PM
Dave69Z's Avatar
The problem is nobody knows anything about them.....AFRs are a known.
I am interested, but without flow numbers and having to buy offset lifters to use with them I just can't justify the expense for them over the ported 190s I am currently running.
Spend $40 and get a cylinder flowed on a Superflow Bench with a 4.030 bore and I bet you get a whole more interest if the flow numbers are good.
Dave
Old May 30, 2004 | 01:07 PM
1BadBrd's Avatar
i agree get them flowed. The numbers you gave were pretty but do they add up?
Old May 30, 2004 | 01:08 PM
1BadBrd's Avatar
i agree, get them flowed. the numbers to gave look pretty but do they add up?
Old Jun 11, 2004 | 04:09 PM
CJ's Avatar
CJ
Believe me, Canfields are 'known' also.
If they had just a little larger combustion chamber id be all over them.
Great set of heads..
Old Jun 14, 2004 | 06:04 PM
Dave69Z's Avatar
In traditional SBC circles yes...in SBF's yes....but LT1's not really.
Dave
Old Jun 14, 2004 | 07:17 PM
EddieP's Avatar
As far as the numbers go, just look up the information for the same head in a gen 1 SBC configuration. I've talked to canfield about their LT1 heads (back when they were still in production), and the LT1 version is virtually a clone of their Gen 1 SBC heads [intake ports, exhaust ports, and CC chamer are identical between the two).
Old Jun 19, 2004 | 03:54 PM
OZ DREAMER's Avatar
Ok i got flow #'s its from Steward Engineering here in Topeka , he has a homemade bench though so the #'s are close to a 600 bench but not exact.
In. Ex.
.100 ....... 67 33.5 ?
.200 ....... 136.2 98.7
.300 ...... 195.8 137.9
.400 ....... 235.6 167.2
.500 ...... 257.3 186.0
.600 ...... 272.8 198.0
These are casting that have not been ported and have a lot more potential in them
These NEED to go...
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
