Turbo Sump?
Old May 24, 2004 | 09:55 PM
Rodrigues's Avatar
Turbo Sump?
http://www.hotrod.com/hotrod/techart..._turb_20_z.jpg
when making a sump, does the bottom of the sump need to be perfectly level with the ground, even if the turbo is draining at an angle? Also, do you want the drain on the sump to pickup the oil from the top or from the bottom (im guessing bottom) but I want to make sure. Besides that, they arent anything but an aluminum box are they?
Old May 24, 2004 | 10:23 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I don't have an answer to your question about the sump, but I don't understand why you would have drainback issues by just running return lines directly to the pan.
My turbos are very low, I have two -10 90 degree fittings right off of the turbos going into the pan just above the oil level sensor. No drainback issues at all.
Old May 24, 2004 | 10:41 PM
Rodrigues's Avatar
Im running a scavenge pump that doesnt seem to be draining all the oil out of the turbos... I recently added another fitting in the pass. side of the car and will be adding another scavenge pump. The oil drain is only like 1" above the oil level.... To get to the pan it has to go up slightly and down again.
Old May 24, 2004 | 11:03 PM
Rodrigues's Avatar
http://kak.com/camaro/closecall/DSCN0632.JPG
http://kak.com/camaro/closecall/DSCN0633.JPG
The drivers side is on a scavenge pump, i just put that new bung in from oil leaks, I havent actually ran it yet but im thinking about just ordering a second scavenge pump.
Old May 24, 2004 | 11:16 PM
96TurboTA's Avatar
Couldn't you turn the fittings, and go in front of the pipes? Looks like it would work better that way.
Old May 24, 2004 | 11:37 PM
EddieP's Avatar
Put a pump on it... the turbo is not going to drain back properly without one. You've got your bearing housing angled up ~30 degrees, and your oil return line still running up hill.
Old May 25, 2004 | 12:10 AM
Rodrigues's Avatar
I know I need a pump, but as well as a pump im wondering if I should try a sump on both sides.
Old May 25, 2004 | 08:53 AM
EddieP's Avatar
Why not try the 2nd pump (which you need either way) first, and save the gimmiky turbo sumps for when you run out of options?
Old May 25, 2004 | 10:30 AM
Chrisbequick's Avatar
Re: Turbo Sump?
I don't mean to go off subject, but does anybody know where to pick up an inlet elbow like the aluminum one on that turbo?
-Chris
G-BODYT56
Jan 14, 2022 11:14 PM
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
