M6 and N2O.... Shifting question.
Old May 18, 2004 | 04:17 PM
Xride's Avatar
How do you make sure you dont spray through the shift?
I was jsut watching a vid I had made last week at the track, and if I get off the gas at all it isnt much, and I shift pretty fast. (have to make up for my ****ting launching skill somewhere)
So how would I make sure I dont spray through the shift? cut the N2O at a lower rpm then I shift is what I would think. but how would that effect getting back on it in the next gear?
Old May 19, 2004 | 02:57 AM
Loony's Avatar
WOT switch?
Old May 19, 2004 | 09:53 AM
LPEdave's Avatar
Typically with a window switch. For example, set the top of the window and your shift light to 6000rpm. Getting back on the gas shouldn't be an issue, you'll come back to WOT in the next gear, maybe at 4500rpm, right inside the window.
Dave
Old May 19, 2004 | 10:36 AM
Xride's Avatar
what if I dont let off enough?
in the video the 2nd to 3rd didnt look like my right leg moved at all. so I'm afraid that I might be full on the gas the whole time.
That would be bad I think.
I was planning on sprayingfrom 3700 to 5800
but my redline was moved up to 6000
Old May 19, 2004 | 11:12 AM
LPEdave's Avatar
So if you set the top end of your window to 5800, then even if you're at WOT thru the whole shift, the nitrous will shut off at 5800. So rpm's go up, at 5800 the shift light goes on and the nitrous goes off (shift light not necessary, I'm just using it as an example), you push the clutch in, RPM's stay above 5800, you shift, you let the clutch out and RPM's drop down to 4500 or so. Nitrous kicks back in, and off you go.
Sound okay?
The non-powershift flavor says that instead of the rev's continuting up during the shift, they drop, but since the throttle isn't at WOT, your nitrous is off because of the WOT switch.
So I've assumed you have a WOT switch and a window switch.
Dave
Old May 19, 2004 | 05:21 PM
Xride's Avatar
Dave
Not yet, they are on my list, that and a MSD digital 6 to retard the timnig for the second stage.
I'll be running a dual stag 150 shot
75 on the window and 75 on a go button for when I get traction.
all on street tires. hope I dont break traction too easy.
Old May 19, 2004 | 06:32 PM
limige's Avatar
i was debating the same issue and this is what i decided to do.
run your window switch lead through a switch on your clutch to insure your not spraying if the clutch isnt fully engaged....
then run it through a wot. switch.
that should insure no problems. curious, what clutch do you use taking that kind of abuse? hows it holding up?
Old May 19, 2004 | 11:34 PM
Xride's Avatar
stocker......
holding up fine, car has 18k miles on it.
havent sprayed it yet.
but if it goes I'll just get a new one, my throw out bearing is going anyways.
Old May 20, 2004 | 07:38 PM
limige's Avatar
holy crap!! your doing that on a stock clutch!!! is it gm or what?
my autozone clutches hardly lasted 4 months of street driving, and i don't powershift.
i blew a spring outta the first one and sheared the inside hub from the outside friction on the second!
going with a spec stage 4 or street twin next.
Old May 20, 2004 | 09:42 PM
Xride's Avatar
Ya stock GM, I've made about 40 passes this season.
all have been shifted the same way, and from the vid it looks like I hardly let off the throtle at all.
if there is slip, I cant feel it.
Old May 20, 2004 | 10:56 PM
mikey9495's Avatar
Lightbulb
Xride,
I sent you a PM. Feel free to write!
Old May 21, 2004 | 06:59 AM
limige's Avatar
wow, well i would say that gm makes a much better clutch than the autozone replacements!
don't temp fate though, expect to replace it with a race clutch soon, clutches can be extremely dangerous when they explode!
i think my switch setup should stop any problems with shifting and nitrous, if anyone knows a better way i'd like to hear it.
Old May 24, 2004 | 08:24 PM
Xride's Avatar
ya I dont expect it to last very long. but it will work till it slips. then a spec will go in.
Old May 24, 2004 | 09:37 PM
Jim_H's Avatar
My stock GM clutch has 58k miles on it now. I have been spraying a 150 shot and I speed shift it while spraying. If you do not heat the clutch up, it will take alot of hard shifting.
Old May 24, 2004 | 10:36 PM
Xride's Avatar
thats very good to know, thanks.
so pretty much let it cool between runs and try not to slip it too much.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
