Would you do this with your rear end?
Old May 16, 2004 | 04:37 AM
ishz28's Avatar
Other addition to the laundry list, 2 broken teeth off of the ring gear. The question is, I have the ring gear from my Richmond set when the pinon teeth broke and I have the pinon from Strange in the car with broken ring gear teeth. Can I combine the two used pieces together? They are 2 series, I figure it's the same chances as buying used gears. Is this a bad idea? The mech I talked to said yes. I can save about 200 or so $$. Thoughts?
Old May 16, 2004 | 08:06 PM
RENE95Z's Avatar
What's the worst that could happen? Maybe having to buy a new set. Give it a try.
Old May 17, 2004 | 07:19 AM
ishz28's Avatar
True, I just don't want to have to pay for an install twice. Is there any way to have the ring and pinon inspected, or is it one of those, take a chance deals. If so, I'll just buy new gears.
Old May 17, 2004 | 07:40 AM
RENE95Z's Avatar
More than likely take a chance sort of deals. There is always that possibly that when ring gears went on the Stranges, it could have weakened the pinion and vise versa for the Richmond.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
