GMS MAF sensor cause lean condition?
Old May 13, 2004 | 10:22 PM
supermo26's Avatar
Question GMS MAF sensor cause lean condition?
Other than the programming, what would cause a lean condition at WOT?
I have a GMS MAF sensor Im thinking of getting rid of, could this cause it to run lean?
I have read they are not user friendly with custom programming.
Car dynoed at 403.3 HP in Florida.
This is a 383 Stroker with AFR 210 COmp heads and Comp 236 242 112 LSA cam.
I want a 27+ more HP out of it NA.
Old May 14, 2004 | 05:07 AM
madwolf's Avatar
Yes, GMS can cause such condition. Mainly because that excuse for a MAF was designed for stock or close to stock cars.
But let me ask you this... What makes you think it's creating a lean condition? The dyno graph? How lean and which RPM range?
Old May 14, 2004 | 11:51 AM
supermo26's Avatar
I'll send you an e-mail titled GMS MAF lean condition
you can look at the graph of the wide band o2.
#3 was Left o2 bung and #4 was right, taken from the y pipe.
Old May 14, 2004 | 02:40 PM
madwolf's Avatar
I tried sending you a reply, but it says your mailbox is full and cannot accept my couple of sentences long message.
I asked you if you could change the scales so that it
shows AFR versus RPM instead of AFR and RPM versus time? Also, please remove that AUX from the graph to make it cleaner.
Thanks.
QuickSilver02
Apr 7, 2015 11:12 AM
pete53
Dec 9, 2014 07:31 AM
Chrisdude
Aug 14, 2002 06:30 PM
Chrisdude
Jul 31, 2002 09:52 AM
Chrisdude
Jul 24, 2002 02:25 PM
