Do Lt1s have an IAT vs Map timing table?
Old May 8, 2004 | 10:17 AM
Highlander's Avatar
I know ls1s have it and tunercat doesn't show it... Do you lt1edit guys have this table??? it would be really helpful if it had it...
Let me know
Old May 8, 2004 | 04:40 PM
madwolf's Avatar
There is a Load (KPA) vs Temp table, yes.
Old May 8, 2004 | 05:35 PM
Highlander's Avatar
TEmp ECT yes... but IAT???
Old May 8, 2004 | 05:41 PM
madwolf's Avatar
Must've not paid good attention. No such thing in OBDI lt1_edit, even in the latest release 2.2.
Old May 8, 2004 | 05:43 PM
Highlander's Avatar
im surprised to see that its not available when the PCM does increase timing when cooler temps are seen... or am i wrong... Even if you lower the IAT 14C the engine temps go down 5-6C which is not enough to go to the other lower spot in temp although it interpolates. But I have the ECT in the 80-92 range 0 out which is where my engine is most of the time and I see an increase in timing from night to day.
Old May 10, 2004 | 02:17 PM
bunker's Avatar
Yeah it would be interesting to see because I still can't figure out if the WOT timing I'm seeing in DATAMASTER at say 5k rpm being 36* is the actual timing or if its really the 33* of timing I have set in my ignition table. Because I dont have a keyed hub with a mark to figure out with timing gun or the IAT table which might be the result of the extra 3* added showing in datamaster I just dont' know
Old May 10, 2004 | 10:12 PM
Highlander's Avatar
I will do a few things to check this out.. this may be the mistery 3 degrees wee see.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
GhostZ28
Dec 7, 2014 11:53 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
