12bolt rearend
Old May 6, 2004 | 02:14 AM
fullcollapse's Avatar
12bolt rearend
i purchased this for my 3rdgen its an old 12 bolt rearend with the spring perches welded on it. To fit under a 3rdgen all thats needed to my knowledge is lower control arm mounts and torque arm mount. Its a limited slip differential with 4.56 gears. The carrier hasnt been installed in the housing yet. The rearend has been painted black and looks very good and the limited slip and gears look brand new as well. I can get pictures if needed. This is a disc brake rearend.
$500.00 pickup preferred but i can ship it truck freight as well.
Old May 6, 2004 | 02:46 PM
dbusch22's Avatar
stupie question... would this work for a 4th gen? i need a 12 bolt for my T/A bad. I've got a 383 and i'm feeling the rear end blues big time!
Old May 6, 2004 | 03:42 PM
americanmusscle's Avatar
.l
.l
same stupie question as him. will it fit a 4th gen??
Old May 6, 2004 | 04:20 PM
sorry guys im pretty sure it wont fit a 4thgen. with torque arm and lower control arm mounts it will bolt right under a 3rd gen and if you take off the spring perches it should bolt under a 1st and 2ndgen. correct me if i'm wrong.
corey
Old May 6, 2004 | 05:04 PM
93TAWicked1's Avatar
Pretty sure it will bolt up and work but I believe it is Narrower than a 4th gen,, maybe its wider I'm not sure..
Old May 7, 2004 | 05:03 PM
chpmnsws6's Avatar
what kind vehicle did it come out of?
Old May 7, 2004 | 07:21 PM
it was out of a chevelle im pretty sure but im not quite sure which year model i can find out tho if i need to..
corey
Old Aug 18, 2004 | 02:24 AM
camaroguy2003's Avatar
Re: 12bolt rearend
whats the width from hub to hub where the wheel studs come out?
mrwz28
Jul 8, 2015 09:11 PM
Flint78
Jun 21, 2015 01:28 PM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Classic Engine Tech
Aug 21, 2002 01:06 PM
