Automatic Trans. Hits Rev Limiter Before Shifting
Old May 5, 2004 | 12:12 AM
uscgreel's Avatar
OK, I HAVE A 94 Z-28 WITH AUTO TRANS. I JUST PURCHASED THE CAR AND WHEN I GIVE IT FULL THROTTLE IT REVS UP TO AROUND 6000 OR WHEREVER THE REV LIMITER KICKS IN, AND THEN IT SHIFTS AFTER IT REV LIMITS FOR A SECOND OR TWO, HOWEVER THIS IS HORRIBLE ON ACCELERATION. MY ONLY IDEA IS THAT IT MIGHT HAVE BEEN PROGRAMED TO SHIFT AT A HIGHER SHIFT POINT BUT WHOEVER PROGRAMED IT SET IT TOO HIGH. ANY IDEAS?
1994 CAMARO Z-28 LT-1, AUTOMATIC TRANS
ONLY MODS: SS HOOD, RK SPORT REAR STEP UP WING, FLOWMASTER, EASY MAF SCREEN REMOVAL.
Old May 5, 2004 | 01:01 AM
ram air camaro's Avatar
that makes two of us.
i think it's the:
*clutche's
*that sensor on the side of the tranny.
well that's what i think.
Old May 5, 2004 | 01:34 AM
IllusionalTA's Avatar
I think you could either get it reflashed w/ a stock prog. and see if that fixes the problem.. or.. borrow a buddies pcm and see if that fixes it... If not it's your car! If it does.. you can probably have pcmforless cut you a program to fix this or do it yourself w/ Lt1edit or Tunercat.. This is not uncommon.. you can also raise the rev limiter to like 6400 or so and it might shift!
Old May 5, 2004 | 01:04 PM
hot_red_z28's Avatar
it could be tranny slippage, or perhaps the previous owner had a higher stall put in, but didn't get proramming to correct the shift pionts, could be a number of things. Is there an aftermarket ignition system in the car? Like and Accel or MSD...
Old May 5, 2004 | 10:00 PM
1984camaroz28's Avatar
Start looking for a trans now. same thing happend to me then the trans puked in a months
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jan 5, 2015 07:14 PM
