Ground Short??
Old Apr 30, 2004 | 12:33 PM
SATANAZ666's Avatar
Ground Short??
Hello,
I have this very annoying problem that just began yesterday, Its not in my T/A, But its in my 99 Grand am. And most of you guys are pretty knowledgeable here so Im asking here.
I was splicing the wires in the Radio harness ( Aftermarket radio got stolen) again so I can put the stock radio on, then all of a sudden I saw this little spark on the Black (ground ) wire. well i didnt pay much attention to it. but now that everything is back in its place everything is weird.
The radio doesnt work at allll! and the interior lights dont turn on!/???????? Huh. Is there a short?/ has anyone had this type of problem??? I mean everything works except the radio and dash lighting....
Old Apr 30, 2004 | 12:49 PM
LS1 RULZ's Avatar
The FRIST rule in car audio...
ALWAYS disconnect the battery first BEFORE you do anything.
Have you checked your car's fuses?
Old Apr 30, 2004 | 01:09 PM
SATANAZ666's Avatar
ummm
yeah i totally agree I should have disconnected the battery!!!!!! but like a dummy I didnt!
see thats also the wird thing...I checked all the fuses and they all checked out good...hummmm
Old Apr 30, 2004 | 01:22 PM
LS1 RULZ's Avatar
Did you test them or just look at them? A fuse can "look" good but still be bad.
Old Apr 30, 2004 | 01:35 PM
SATANAZ666's Avatar
i checked them with th little fuse checker that lights up if the fuse is good......w at else can cause this??
Old Apr 30, 2004 | 03:26 PM
Rashiki's Avatar
it definately sounds like a fuse...
what did you touch to the ground wire, perchance? ground wires don't just spark.. test the fuse at the back of the head unit as well.
Old Apr 30, 2004 | 03:49 PM
SATANAZ666's Avatar
the stock headunit has a fuseinit...where??
I touched some other wire i think or maybe some metal
Old Apr 30, 2004 | 11:59 PM
Javelin3o4's Avatar
did you check under the hood aswell for fuses?
Old May 3, 2004 | 10:14 AM
SATANAZ666's Avatar
HI,
THE thing is ive checked almost every fuse imaginable.....unless theres one you guys can point out.....Ive checked the unes under the hood, the ones on the side of th dash..you name it.
HELP ME PLEASE..
Old May 3, 2004 | 02:47 PM
Tair's Avatar
Regardless of whether the fuse tester says the fuse is good....change the "Radio" fuse on the side of the dash. Many fuses will allow SOME current to still go through them, and therefore test 'ok', although they are not allowing enough current to go through to power the radio. Please just try this out first....you don't even have to buy a new fuse just yet....find another fuse in your car that has the exact same amperage as the fuse marked "Radio" and swap the two. I almost guarantee this will fix it for you!
Old May 3, 2004 | 02:50 PM
SATANAZ666's Avatar
will the fuse be the problem for the dash lights and climate control lights too?????
Old May 4, 2004 | 12:28 AM
Tair's Avatar
for dash lights you can try pulling the "Courtesy" fuse....
Old May 4, 2004 | 05:47 AM
LS1 RULZ's Avatar
It's got to be one of two things. Either there is a blown fuse or you have accidently unplugged something somewhere breaking the circuit to the lights.
walt355
Mar 16, 2016 09:35 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
ZXXVIII
Sep 1, 2015 10:13 PM
4586
Aug 22, 2015 01:09 AM
