SS rims on a 94
Old Apr 29, 2004 | 08:55 PM
BlackandTanZ's Avatar
SS rims on a 94
Ok, heres the deal. i got some 17x9 ss wheels from slp during the winter. i put them on recentlu and now i have a small problem, at full turn i am getting some rubbing against the plastic of the inner front fenders. the tires are 275 40r 17, and i was under the assumption that they would not rub. any suggestions?
thanks
Justin
Old Apr 29, 2004 | 09:05 PM
silverz28's Avatar
Mine never rubbed in the front but mine is a Camaro. I don't know if that makes a difference. Did you get the correct offset? I don't even know if SLP has different offsets or not, but worth checking into. Also, do you have a lowered car. Mine is lowered but only a little.
Old Apr 29, 2004 | 11:40 PM
mine is also a camaro. and no it is at the stock ride height. the offsets are correct. does anyone else have this rubbing problem? i know a ton of people are running this wheel /tire size combo, so is my car just a freak or what?
thanks
Justin
Old Apr 30, 2004 | 05:07 PM
MustangEater82's Avatar
Mine don't rub(I have a 2000 but that should not really matter)
Though a freind of mine with a 35th LE Camro SS his 10-spokes rub a little at full lock.
Old May 1, 2004 | 12:47 PM
Lt1 and Ls1's Avatar
Crazy, that is the first time I heard of the 275 rubbing. Good luck!
Old May 2, 2004 | 02:19 PM
yeah, mine are the 10 spokes also and they rub only at full lock. hopefully it isn't enough to really do any damage
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
