Trans mount
Old Apr 27, 2004 | 05:12 PM
dboyw's Avatar
Trans mount
Hello all. I am getting ready to buy an Energy suspension kit for the camaro. I want to buy the Z28 box cause I plan to put the rear sway bar on at the same time. What I am not sure of is the trans mount the same for a v6 auto and a Z auto? Are there any other differences in the bushing I am not aware of?
Thanks for the help.
Old Apr 28, 2004 | 12:13 AM
RS96Silver's Avatar
it should be the same mount...i bought a mount from them and it was interchangeable with i think every year camaro
Old Apr 28, 2004 | 01:08 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
that is incorrect, the trans mount produced by ES will not fit on the 3.4L unless you modify the trans crossmember, its not hard, but you will need to drill another hole in the crossmember or lengthen the stock hole. also the poly trans mount is shorter than the stock one , so you will need to rig up some sort of spacer
Old Apr 28, 2004 | 02:09 PM
RS96Silver's Avatar
i have a 3.8 so thats probly y i didnt have too
HarleyZ28
Oct 5, 2015 06:23 AM
Jun 6, 2015 08:27 AM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
x7x7
Aug 15, 2002 06:49 PM
