How to remove turn signal lever
Old Apr 26, 2004 | 05:07 PM
juny44's Avatar
How to remove turn signal lever?
I have a 96 camaro. I need to replace the turn signal lever. I broke the old lever. Now a 1/4" piece is all that remains. I already disconnected the cruise control. I already have the new part and it has a c-clip at the end. How do i remove the c-clip? Do I need a special tool?
Old Apr 26, 2004 | 05:39 PM
HBHRacing's Avatar
if you mean just the lever it turnes and pulls out. might be har dto get at if you broke it. but it should just pull
Old Apr 26, 2004 | 07:22 PM
ss00's Avatar
Before you pull the old one off, attach a piece of thin wire to the connector end of the old one first. That way after you pull the old one off and the wire comes up through the steering column, you can attach the wire to the conector end of the new one to pull the harness down through the column with the same wire.
Old Apr 26, 2004 | 08:05 PM
HBHRacing's Avatar
I belive he means the lever itself.. not the switch.. I think
Old Apr 27, 2004 | 11:31 AM
juny44's Avatar
I dont have a problem with the cruise control wires. I'm just unsure about how to remove the lever itself. I have the new lever and the end that goes into the column is keyed like a mixer blade, so it can stick in the hole. I just cant remove the c-clip attached to the lever. Do you guys think I am going about this the wrong way? Is it necessary to remove the steering wheel to replace this part?
Old Apr 27, 2004 | 11:49 AM
HBHRacing's Avatar
no, your on the right track. you don;t need to remove the clip. you just pll on it and it comes out. it;s a litle tricky but pretty streight forward. The hard part will be that it;s broken off.
Old Apr 28, 2004 | 04:16 PM
juny44's Avatar
Thanks for the advice HBHRacing. I grabbed some vice grips and yanked the broken piece out. The new lever went in easily. No more jumping through the window to get into my car anymore.
Old Apr 28, 2004 | 04:25 PM
HBHRacing's Avatar
glad you got it worked out
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
