Best slicks?
Old Apr 20, 2004 | 01:09 PM
kaoticcamaross's Avatar
Best slicks?
I need some slicks for my 95 z28 and I wanted to know whats the best slicks for the money and how much am I looking at paying?
Old Apr 20, 2004 | 02:14 PM
IDOXLR8's Avatar
How much power are you putting down. Also do you have a built rearend?
Old Apr 20, 2004 | 03:21 PM
Ok well I have a rebult tranny with a shift kit so the car is not getting traction in the shifts. I was told best thing to do is get slicks so I will get the track down the track and not end up with burn outs at every shift point down the track.
Old Apr 20, 2004 | 03:29 PM
magius231's Avatar
be careful who you listen to
do not get slicks unless you are prepared to replace your stock rear end. Automatics have a much easier time with them than manual tranny guys, but theres still a chance that the first run you make will send your rear end away in a shower of metal pieces. The rear ends in these cars are notoriously weak under that kind if stress, and upgrading the rear costs anywhere from $1500-$2400 depending on where you go.
You can do it, but like I said, just be ready if/when it happens
Old Apr 20, 2004 | 05:25 PM
So don't go to slick unless I upgrade my rear end? So right now I should just run with the huge traction loss?
Old Apr 20, 2004 | 05:31 PM
scoobysnax83's Avatar
why don't you go for a happy medium and get some nitto's? They are a slick composite that is street driveable. Best of both worlds., and not as bad on the rear as full slicks. I ran them on me 160,000 mile rear about 10 times down the track with no problems
Old Apr 20, 2004 | 08:08 PM
I'm runing nittos right now and I have that huge traction loss
Old Apr 20, 2004 | 08:10 PM
ok then, what "else" do you have done to your car. Nittos will hold just fine with a simple shift kit.
Old Apr 20, 2004 | 08:38 PM
Um rebuilt tranny with a shift kit. PCM programming, 160 thermostat, and slp loudmouth exhaust thats it. To me its basically stock.
Old Apr 20, 2004 | 09:06 PM
get some new nitto's or heat them up better in the hole. I can't imagine how you're loosing traction in all gears. How about posting up some times, like 60's, 1/4 and trap speeds.
Old Apr 20, 2004 | 11:59 PM
All I got are 1/8 mile times but heres a couple times form the last time I ran.
run1 run2 run 3 run4 run5
60ft 2.1898 2.707 2.1799 2.2061 2.2635
330ft 6.00 5.9972 6.025 6.0499 6.0792
1/8 et 9.1590 9.1716 9.2012 9.2095 9.2254
1/8 mph 78.29 77.79 77.77 78.36 78.56
Old Apr 21, 2004 | 12:23 AM
QCKZ28's Avatar
to be blunt your sixty foots suck.... if those are drag radials
what is the #'s on the tire?
what tire pressure do you run?
describe your burnout....
drag radial tires cut 1.6-1.7 sixty foots easily
Old Apr 21, 2004 | 12:33 AM
CamaroBoy96Z28's Avatar
Perhaps on a much more modified car but on a bolt on or near stock car, thats not going to happen, at least often. 1.7s are possible but not at all likely. Mid 1.8s-under 2.0 should be easily attainable with great driving on DRs though.
Old Apr 21, 2004 | 12:44 AM
QCKZ28's Avatar
agreed that a stock/bolt on A4 car cant cut 1.6-1.7 sixties, i was just saying that a drag radial is capable of it or less
from reading this post, i think that he doesnt have DR just nittos.
Old Apr 21, 2004 | 11:49 AM
You never said anything about drag radials. You just said nittos and so I answer yes. I have nitto 450's.
