What's the best way to fill in license plate holes?
Getting the front clip repainted, and and going to go !plate. But there are the holes there, how should I go about filling them?
http://www.bfranker.badz28.com/fbody/repaint.htm
QUOTE from the above site
This next part is an "extra."
This car came from Texas. Texas is a state which requires the use of a front plate. Because of this, my car had two big and ugly screw holes in the facia. I asked Eric if there was anything he could do to fix this and he said SURE! He used a method/technique I had never heard of before. He put some Locktite Quicktite Super Glue Gel on a piece of 180 grit sandpaper. He then placed the dab of glue on the screw hole then began sanding. He said what this does is creates a very hard compound that is made of the super glue and dust from the sanding! He did this a few times with the gel then switched to using a superglue liquid on 320 grit sandpaper. This was then followed up by sanding with straight 320. The result was a filled hole that was smooth to the touch! This can be primered immediately and is much better than bondo because it won't shrink and/or crack! A very neat little trick which can also be used to repair small cracks and tears in fiberglass.
Well I thought this was an ingenious idea atleast
This car came from Texas. Texas is a state which requires the use of a front plate. Because of this, my car had two big and ugly screw holes in the facia. I asked Eric if there was anything he could do to fix this and he said SURE! He used a method/technique I had never heard of before. He put some Locktite Quicktite Super Glue Gel on a piece of 180 grit sandpaper. He then placed the dab of glue on the screw hole then began sanding. He said what this does is creates a very hard compound that is made of the super glue and dust from the sanding! He did this a few times with the gel then switched to using a superglue liquid on 320 grit sandpaper. This was then followed up by sanding with straight 320. The result was a filled hole that was smooth to the touch! This can be primered immediately and is much better than bondo because it won't shrink and/or crack! A very neat little trick which can also be used to repair small cracks and tears in fiberglass.Well I thought this was an ingenious idea atleast
Noct
Jul 14, 2015 01:18 AM
ducttape1975
Jul 10, 2015 06:29 PM
