Boost Gauge Question
Old Apr 15, 2004 | 06:20 AM
IDOXLR8's Avatar
Finally, got my car running and when I started it up I noticed the boost gage was at 0. That tells me that there is a vaccum leak somewhere in the system. I noticed when I hit the throttle the needle would move into boost. Currently the interior is apart because I just removed the airbags and heater core. I am thinking I may have put a hole in the vaccum line or kinked it when I removed the A-pillar. Has anyone noticed and increase or decrease in vaccum when going from a twin high flow setup to a big frount intercooler? The thing that bothers me the most about the gage is when I shut the car off it goes from 0 to 5 psi of boost. In the past when I shut the car off it went to 20 in. of vaccum. Could this be a faulty gage? Thanks in advance.
Old Apr 15, 2004 | 11:52 AM
Ultra_Dog's Avatar
If everything is off, it should read "0" or very nearby. The gauge has a large blip denoting 0 and my car sits on the south side of it when the engine is off. The only power is for the light. When I am in boost, I typically add a pound or two to compensate for the gauge error. I have a combo Vacuum (-30) and Boost (+20) gauge.
If your gauge is not at 0, then it is bad.
Old Apr 15, 2004 | 11:58 AM
IDOXLR8's Avatar
Yeah when I shut my car off it goes from 0 to 5psi of boost. In the past it would go below 0. Is there anyway to get a boost gage recalibrated? Oops I forgot to mention that there is a clamp missing at my TB.
Old Apr 15, 2004 | 02:14 PM
Birdie2000's Avatar
Mechanical gauge?
Old Apr 15, 2004 | 02:22 PM
IDOXLR8's Avatar
Yes this is a mechanical gauge.
Old Apr 15, 2004 | 03:33 PM
95 Silver TA's Avatar
I would assume its a bad guage too. When I shut my car off, my guage goes right to 0 and stays there (Always did). If I have the blower hooked up and I hit blip the throttle at idle, it would go into 3 psi of boost real quick and then return to vacuum with the car running but it Always shoots back to 0 when I shut the car off and it stays at 0. I think it might be a bad guage. You might want to check the back of the guage, mabee there is a **** on in the (inside) shown on the back of the guage that you can adjust it somewhat so it zeros out . I think either my FP guage or My Boost guage had some kinda **** that would allow you to adjust it so you Zero it out if needed, I am just not sure if its the boost guage or my Electric FP guage that had that little adjuster **** but you may want to check that first.
Thx,
Claude
Old Apr 16, 2004 | 07:02 AM
IDOXLR8's Avatar
[QUOTE]Originally posted by 95 Silver TA
Thx,
Claude
[/QUOTE/]
I have come to the conclusion that I have a bad gauge. Time to get a new one My gauge is sitting on 5lbs of boost.
Old Apr 16, 2004 | 05:22 PM
ltlhomer's Avatar
I have one you can borrow if you wanna just check and be sure. I live in southfield or warren depending if I'm at my dorm or the parents house. Let me know if I can be of any use.
Hate to see you drop $50 for nothing.
Old Apr 16, 2004 | 09:44 PM
IDOXLR8's Avatar
Thanks for the offer but I am 100% sure that is the problem after talking to the techs at AUtometer. Plus I know where you live Down the road from Tony.
Old Apr 17, 2004 | 12:18 PM
ltlhomer's Avatar
Well as long as you don't tell them what's cooking in the garage, then it's all good.
Also, since you know where I live, it gives you no excuse not to stop by with your ride once it's done.
Old Apr 18, 2004 | 06:04 PM
IDOXLR8's Avatar
I wish I could drive my car that far but it is not a street car. FInished up alot of it today. I am waiting for the top dash piece to come so I can install it and be done. I am picking up my slicks on Tuesday and having them mounted on my Bogarts. Then I should be ready for NOrwalk.
Old Apr 18, 2004 | 09:42 PM
ltlhomer's Avatar
Let me know when you're going to run it and I'll be sure to come down and spectate.
Old Apr 19, 2004 | 06:57 AM
IDOXLR8's Avatar
I am going down May 14. The Grand Prix clubed rented out the track for that day.
Old Apr 19, 2004 | 09:04 AM
ltlhomer's Avatar
Sweet...any chance you can sneak in another camaro?
I BETTER be ready by then.
Old Apr 19, 2004 | 09:15 AM
IDOXLR8's Avatar
There are not any openings. Plus there is a waiting list. I am sure a few people will not make it out so there may be some openings. WHat all do you have left to do on your car?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
Antz97ZNJ
48
Jun 20, 2002 06:09 PM
