White smoke out the back
Old Apr 12, 2004 | 11:31 AM
kinyu's Avatar
Hey guys, when I "gun it", I am getting white smoke out the tail pipes.
My two theories are:
Fuel delivery problem, maybe too rich or too lean,
or coolant leaking into the piston.
What do you guys think?
Old Apr 12, 2004 | 11:44 AM
PhantomTA's Avatar
Moderator
Oil is blue
Fuel is BLACK
Coolent, is usually white
Old Apr 12, 2004 | 12:51 PM
Loony's Avatar
Re: White smoke out the back
Coolant in your piston....maybe not. Hahahaa, anyways look at the smoke kinda off to the side and see if you see a slight blue tint. If so then its oil. If not, its coolant.
Old Apr 12, 2004 | 09:59 PM
00LukeyWS6's Avatar
Do you have cats? If not then its normal (I think, not really but almost all catless LS1 emit nice cloud of smoke when gunning it)
Old Apr 12, 2004 | 11:59 PM
robb4964's Avatar
Not white..Usually black .
Old Apr 13, 2004 | 01:07 AM
chpmnsws6's Avatar
i puff out a hint of blue when i start the car and black when i'm racing
Old Apr 13, 2004 | 01:51 PM
kinyu's Avatar
Yeah, I have cats. Maybe I'll have to bite it and take it into the shop just to make sure.
Old Apr 13, 2004 | 02:10 PM
Red96Lt1's Avatar
Do you have alot of miles on the car. Has it ever been overheated? White smoke is not good. Could be blown head gasket or cracked heads.
Old Apr 13, 2004 | 04:30 PM
slayer6x6's Avatar
The blue smoke is probably you valve seals, and the black is from too much fuel.
Old Apr 13, 2004 | 10:08 PM
pearlpurple's Avatar
keep a close eye on coolant level
check your oil frequently for milkshake look
at idle or if you rev her up while parked and you see the smoke maybe have someone rev it up and smell the smoke, if has a sweet smell and is white it is coolant.
mr28
Apr 20, 2016 05:44 PM
dale3in98
Feb 14, 2015 12:18 PM
NewsBot
Dec 24, 2014 11:05 PM
mr28
Nov 23, 2014 11:11 AM
