Why does my fan wiring keep getting fried?
Old Apr 11, 2004 | 04:18 PM
DanTheIROCMan's Avatar
This problem seems to manifest itself at least once a year. At some point, my fans just stop working. Each and every time, it is because the wires get fried. You can actually see a hole was burned out in the side of the wiring harness connector that attaches the fan wiring to the 2 relays next to the batter. I just don't get it... What could be causing this?
Old Apr 11, 2004 | 04:37 PM
AutoRoc's Avatar
Do you carry a fire extinguisher?
Old Apr 11, 2004 | 04:55 PM
Zepher's Avatar
Probably the fans are going out and causing a high amp draw that is melting the wires. Replacement fan motors are about $23 each.
Old Apr 11, 2004 | 05:28 PM
TheGreatJ's Avatar
I'm with Zepher on this one....the only thing that will melt wires is too much current (or getting against the exhaust which is pretty unlikely in this case.) Overcurrent means a short of some kind, and inside the fan motor is the most likely place.
If this is the case the fan will still run, but won't move as much air which leads to reduced cooling and more run-time for the fan. This leads to more current through the wiring and more heat. As the wiring gets worse it conducts less voltage which means the fan runs even slower, which leads to more heat. It's one of those problems that kind of feeds on itself and eventually it gets to the point where it won't work at all.
Old Apr 11, 2004 | 06:14 PM
aklim's Avatar
You sure you didn't put too thin a wire when your eplaced it last time?
Old Apr 11, 2004 | 07:42 PM
IROC-T's Avatar
B I N G O !
Old Apr 11, 2004 | 08:06 PM
Okay, well, I'm pretty sure I replaced the fan motors not too long ago, but I can't remember if I had purchased new ones or just picked them up from a junk yard. What's the life expectancy on these puppies? Is it me or do these cars have major cooling issues?? Car seems to always run pretty hot, even when the fans were on. Maybe what you said was right, the fans were not rotating as fast as they should've, thus causing the car to run hot and drawing too much amps from the battery, causing the wire melt down. Ya, it's also possible I used to small of a wire last time.
Is there way to test the fans so that I don't just throw money at them unnecessarily?? If so, how? Thanks!
Old Apr 11, 2004 | 09:07 PM
aklim's Avatar
I have my original ones, if that helps any
Old Apr 12, 2004 | 12:40 AM
Zepher's Avatar
You can hook up an ammeter to them and see what the current draw is.
You;d need to also hook up the meter to someones fans that work great to get a reference value.
Sometimes the front of the radiator or condensor or in-between will accumulate a lot of dirt and debris, make sure it is nice and clean.
Old Apr 12, 2004 | 09:47 AM
I just bought a new one from Autozone, so that will be a great referrence. Now, I just gotta find an ampmeter. They aren't too expensive are they? Where do you get them from, RadioShack??
Old Apr 12, 2004 | 10:47 AM
aklim's Avatar
I suppose you could get a cheapo one from Radioshack.
Old Apr 12, 2004 | 08:16 PM
Zepher's Avatar
just get one that can read at upto 20 amps just to be on the safe side.
I think the Fluke I have only does 10amps on the 12v side. If it stops raining this week, I'll measure mine and see what it reads.
Old Dec 29, 2004 | 05:02 PM
94LT1Maro's Avatar
Re: Why does my fan wiring keep getting fried?
my cooling fan died recently and I've replaced the fan motor and the relay switch. After I replaced the relay switch there was an electrical fire after at least 2 minutes of the car idling. Could've overcurrent have caused this and if so where would it have occured. If the relay and the motor are brand new I don't see where it could've happened?
Magenta_Hearts
Mar 25, 2015 10:24 AM
NewsBot
Mar 13, 2015 07:15 AM
NewsBot
Feb 6, 2015 05:00 PM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
