air pump question
Old Apr 5, 2004 | 09:58 AM
jasonss's Avatar
air pump question
just had ls1 edit done last night, had the air pump turned off, i want to remove it, to get rid of the annoying air check valves clicking, have mac headers with high flow cats and y-pipe, is it easy to remove the air pump
Old Apr 5, 2004 | 10:04 AM
Mike94ZLT1's Avatar
Yes, pull off all the hoses, and make sure you have block off plates for the headers. The air pump is on the drivers side behind the turn signal and headlight. Jack the car up and there are 2 or 3 10mm bolts you have to take out, and the panel will bend down and voila! its right there.
Old Apr 5, 2004 | 10:28 AM
2001NBMZ28's Avatar
Since you have the codes deleted you should be able to pull the AIR PUMP fuse to disable it until you get around to pulling everything.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
