Who is running a fogger?
Old Sep 16, 2002 | 08:18 PM
onebad96T/A's Avatar
How are u getting the fuel? from the schrader valve
And does anybody have any pics?
Old Sep 16, 2002 | 09:19 PM
ChrisJ325's Avatar
Im running the TNT wet kit, and I get my fuel from the schrader valve connection. I think thats how all wet kits do it, it was how it was detailed in my TNT instructions.
Old Sep 16, 2002 | 10:28 PM
CustomN2O's Avatar
Now Im assuming when you say "FOGGER" you mean a direct port kit? If I am wrong, then disregard. If it is a direct port nozzle kit, then I would recomend getting your fuel from a seperate supply. Run a second fuel cell and pump, or a bigger main line, and regulate off it to the solenoid. I recomend this becuase if you are running a direct port kit, you are most likely going to use more then 150hp, and I wouldnt trust the shrader valve to be able to supply that much more fuel, without starving either the injectors, or the nozzles. Again, just an opinion.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
