Wheel spacers on a Trans Am
Old Mar 30, 2004 | 06:48 PM
Njgunslinger's Avatar
anyone here use wheel spacers on their Transam, and if you have, what size, and did you replace the studs?
thanks
Old Mar 30, 2004 | 07:06 PM
I was thinking of getting a 1/2" spacer? So obviously i have to replace the studs, anyone have a problem changing the studs to longer studs? Do you have to remove the axle to do this?
Old Mar 31, 2004 | 11:05 PM
redz28kn3007's Avatar
I have 1" spacers with 9.5 X 17" rims and 275/40/17 tires and it fits well and looks good. The tires don't stick out and don't rub if you 'massage' the lip on the fender slightly.
It all depends on your wheel size and backspacing - with the stock rims/tires you should be able to fit 1.5" or 2" spacers.
Check www.powertech.de and look for the spacers for a 84 and up Corvette... that's what I bought... there are also many deals on Ebay... some of the are 'made to order' - two spacers for 100$
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
CaRParts102
Dec 6, 2014 08:45 AM
