Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Trans mount bad after 30k???
Old Mar 30, 2004 | 12:29 PM
mavricki18's Avatar
Every time i go to rip in to 2nd there's a loud clunk on the floor board. I know my Y pipe hits because i have a cat-less Y-pipe, but the sound sounds a little more deep and heavy than an exhaust pipe. Is it likely that i have a bad trans mount?
Old Mar 30, 2004 | 12:56 PM
Eddie95Z28's Avatar
Originally posted by mavricki18
WOW i cant type
Trans Mount that is
If it was a bad mount it woul dmost likely make a clunk anytime you gave it a good shot on the gas and whenever tiy took off in first or shifted.
Old Mar 30, 2004 | 01:58 PM
mavricki18's Avatar
Originally posted by robvas
I've known people to go through a trans mount or two in one year.
Try a poly mount, NAPA has them in stock for $29
My friend went through 3 of them in 1 summer on his 94 T/A auto. wasent long before he needed trans rebuild and head gaskets. Than he sold it and now hes working on beating up his 2000 WS6
Old Mar 30, 2004 | 02:01 PM
T.V.'s Avatar
My reans mound lasted well past 1,000,000 miles!
Old Mar 30, 2004 | 02:22 PM
Timberwolf's Avatar
you just have to have them calibrated every 20k miles. And none of the Bleem standard calibration. You have to go with Frammlestat!
Old Mar 30, 2004 | 02:28 PM
T.V.'s Avatar
Oh sure, get all technical and stuff............
Old Mar 30, 2004 | 04:14 PM
mavricki18's Avatar
After reading up on them i found that the best thing to do would be go with a fluctuating dingle arm type mount. It has a direct connection to the hycunution valve so it can regulate the hydrostatic pressure in the vapor chamber correctly. Than you can delete your exhaust bearings with out throwing a code.
Old Mar 30, 2004 | 05:50 PM
Hot Rod Hawk's Avatar
and if all the above fails try checking the rubber mount for the torgue arm on the tail housing of the trans. Is the rubber still in there or is it gone and beating it's self to death?
Jun 6, 2015 08:27 AM
Jan 5, 2015 07:14 PM
Jazsun
Dec 29, 2014 12:14 PM
x7x7
Aug 15, 2002 06:49 PM
