Pics of damage, nitrous caused..
Old Mar 19, 2004 | 04:16 PM
KamaroL98's Avatar
A few monts back i posted about spraying to big of a dry shot, had no compression in two of my cylinders, all the spark plugs were BURNT, gas smell, car wouldnt run hardly, etc... Every guessed i burnt a piston or two. Well, pull the heads and the pistons were fine, however the two cylinders that had no compression, one of the valved had a big hole through it, and the other had a hair line chip. Fast forward, i get the heads back slap em on and car fired right on up stronger then ever!!!! here are a few pictures of this adventure.
This is the worst damages valve...
http://www.scfyb.com/phpBB2/album_pi...76771d4f04b8cd
This is the motor with heads removed.
This is me haveing to much fun to be working on an LS1 at 3am.
This is what happens when you just throw the valve covers in the washer with you clothes useing arm and hammer, they turn RED!
http://scfyb.com/phpBB2/album_person...2cc37efdcadd7f
These are the ported/polished Mac DADDIES about to be slapped back on!
This is is back together, meaner, LOUDER, and faster then before!
This is her in my garage...
At a hang out spot!
Old Mar 23, 2004 | 07:33 PM
Hawk's Avatar
car looks good.
Next time be more careful, good to see it's back together though.
Brian
Old Mar 23, 2004 | 11:01 PM
12Second3rdgen's Avatar
I think it would be better worded "Pics of damage I caused" because you are an idiot... That level of nitrous usage with pump gas, no timing retard and stock heat range plugs is ridiculously dumb.
Old Mar 23, 2004 | 11:14 PM
KamaroL98's Avatar
And you have a slow, wimpy 12sec car. I know how much was to much. I expected something to break, but i honestly did think it would have made it through the 1/8th, fact is i didnt care if it broke. i can work on my car and have money to fix it if something breaks. sometimes i just need a reason to work on it, like messing it up.
Old Mar 24, 2004 | 12:03 PM
You sprayed a 225 dry shot with a stock fuel pump, injectors, no timing retard, stock plugs and premium gas.
Those times are on radial T/A tires minus a few mods and tuning. On slicks with my new mods my car may even go into the 12.1's naturally aspirated, and I have an NOS cheater kit on top of that. Then again, I know what I am doing.
Old Mar 24, 2004 | 12:07 PM
KamaroL98's Avatar
T
You dont know anything about my car obviously....
Old Mar 24, 2004 | 02:02 PM
PM conversation with you, sorry 215 dry shot not 225
ooo
215 dry shot.
a 75 shot and a 150 shot..
Re: ooo
quote:
12Second3rdgen wrote on 01-14-2004 09:12 PM:
quote:
KamaroL98 wrote on 01-14-2004 08:44 PM:
215 dry shot.
Whoa dude that is big. What were you running previously? Timing retard? Fuel?
None of that.... I know it was stupid...... WHat do u think happend? ran lean?
Old Mar 24, 2004 | 03:54 PM
IRONFIST's Avatar
man, you lucked out
Old Mar 24, 2004 | 04:14 PM
KamaroL98's Avatar
Moron, i KNEW **** would brake. I said that 30 times, i kne wi should have changed my timeing, had it tuned, etc. I wasent useing a stock fuel pump or plugs btw, but im not keeping it stock anyway. Unless your going to stop talking ****, stop replying to my post.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
