Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
My TA Wont Start!! HELP
Old Mar 19, 2004 | 03:50 PM
99TransAmWS6's Avatar
It started up fine at first..i drove it for maybe 20 mins..got to the gas station..put some gas in..and went to start the car..and it wouldent turn..no cranking..no signs of battery dead or anything like that. Waited a couple mins..started right up..Drove it home..put it in the garage...went out to start it today..and it wont start again. When i turn the key nothing happens..the security light blinks..please help!!
Old Mar 19, 2004 | 06:35 PM
triumph's Avatar
Do you have the factory keyless entry/alarm????? If so find the box under the dash and unpulg it then see if the car will start. Steven
Old Mar 19, 2004 | 07:42 PM
under the passenger side or driver side?
Old Mar 19, 2004 | 07:46 PM
triumph's Avatar
Drivers.
Old Mar 19, 2004 | 07:53 PM
what should i be looking for little more specific.
Old Mar 19, 2004 | 09:22 PM
triumph's Avatar
There should be a box(alarm module) about 3"X5"X1" with a connector going to it unplug the connector then see if it starts. Mine did the same thing. Steven
Old Mar 20, 2004 | 01:19 AM
notstock4long's Avatar
I know a lot of times when the starter is going, it will work when cold, but not when warm.
Similar thing happened to me, I tapped the starter with a pipe (lightly enough not to break it, but a decent tap) and it has worked fine ever since. Just a thought.....
Old Mar 21, 2004 | 11:14 AM
mavricki18's Avatar
My buddy had that problem in his 94 T/A
you have to wait like 3 min till the securitylight turns off to try and start it again .
I guess its a problem with the Ignition switch and the little chip on the key.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
