Anyone convert a carb intake to EFI and done it THEMSELVES?
Old Aug 5, 2002 | 12:26 AM
89ProchargedROC's Avatar
Post Anyone convert a carb intake to EFI and done it THEMSELVES?
Well i'm going to give it whirl. I have a pair of track 1 heads and dont want to bother trying to monkey around and get my small *** ports on my holley tunnel ram lower to fit the ports on my heads
so ive decided to buy an intake with ports big enough to match them and convert the intake to EFI using some injector bungs and bar stock fuel rail.
I was just curious if anyone has ever attempted this themselves and can give me some pointers
thanks
Old Aug 5, 2002 | 12:38 AM
zturbo's Avatar
Post
The one thing is make sure you layout the injector angles and distance correctly. I have read on a few sites that convert them that is to watch for that.
From looking at it though it really doesnt look that hard to me to do. Just take your time
Steven
383 Inches of stroked turbocharged fun.
If one is good shouldnt 2 be great?????
TURBO=TORQUE
TORQUE=FUN
My Car
Old Aug 5, 2002 | 01:39 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by zturbo:
Steven
</font>
Well, placing them correctly in the center of the port is obvious....and i have heard that angle plays a role in the "type" of injector you use ie bosch or pintle type
you happen to have those "sites" you speak of?
Old Aug 6, 2002 | 04:04 AM
Racing's Avatar
Post
I´ve done this numerous times.
In fact i´m finishing one at the moment.
Like the guys say..nuthing much to it really.
Couple of things to have in mind;
1/Cut the holes for the bungs on a bridgeport.This will assure that the 4 holes per row are more or less in line at least.Think of it much like setting up nitrous nozzles.
2/Be careful when putting the TIG to the bungs.Heat involved will put a warp on the intake more often then not.Take your time,and weld a little at a time.Check EVERY flat surface for straightness when done.resurface as needed.
3/Your die grinder is your best friend
4/Appreciate the fact that it´s VERY hard to oversize injector rails,on the other hand it´s VERY easy to do the opposite-with FP fluctuations following suit.IMO we´re talking 5/8" inner dia minimum.
5/TWM makes for some nice looking FPR;s in all forms imaginable.In contrast to a lot of other crap floating around,they work.
6/Think BEFORE doing any cutting..*LOL*
DVC-2001.Racing
482 cubes of fogger injected thunder in a 71 z-28.
Viking thunder
Mail me at
racings email
Old Aug 11, 2002 | 01:54 PM
z28kid93's Avatar
Post
anybody have some websites for people that have done this? Then I'm guessing that you use a 90* elbow on top of the intake. What do you use for a throttle body? Thanks!
Chris
Old Aug 11, 2002 | 10:13 PM
Post
Yup, i am going to be using a precision elbow adaptor with a ford throttle body
i'm going to mill down the top surface of the victor junior and the bottom of the elbow and get it all to fit under my stock hood
In a thirdgen with the stock hood there is 9.75" of clearance for intakes total. That is with the hood insulation gone and some hood bracing mods
Old Aug 11, 2002 | 10:18 PM
z28kid93's Avatar
Post
can you do this to pretty much any intake manifold? also that adaptor, is there other throttle bodies they could adapt it to? or did you find that the ford was the best option?
Chris
Old Aug 13, 2002 | 11:59 AM
madman69's Avatar
Post
Go to www.madmanandcoracing.com/madmanscamaroupdates.html there are pics of the manifold we did. If you have any questions give me a hollar.
Insanity at its fastest
Worlds Fastest Blown 4th Gen
9.18@ 152
First 9 sec. PROCHARGED F-Body
In Memory of TONY OWEN driver HYDROMANIA
Old Aug 13, 2002 | 12:58 PM
z28kid93's Avatar
Post
another question...is it possible for you to do the conversion AND then run a direct port nitrous system tapped into the runners? or is that a point in which structural integrity might be compromised?
Chris
Old Aug 13, 2002 | 03:37 PM
Post
i've seen it done before, but most people run the system dry for easier conveinance
Old Aug 13, 2002 | 03:39 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by z28kid93:
Chris
</font>
Accel used to make a adaptor to bolt up the GM style throttle body but it has been discontinued. Basically the ford is the only one i know unless you make your own
Yes you can pretty much convert any carb manifold to fuel injection, just make sure its a singleplane
Old Aug 13, 2002 | 06:46 PM
z28kid93's Avatar
Post
pardon the ignorance, but how much is parts and labor on a the conversion?
Chris
Old Aug 14, 2002 | 10:00 AM
Post
A good machine shop that knows what they are doing would probably charge you in the $300 range and that is complete but no elbow
The cheap way to do it is the way i'm doing it:
Buy injector bungs: $40 from www.youngsperformance.com
Buy 2 feet of .500 bar stock fuel rail: $10 a foot from www.force-efi.com
Then just have the machinist throw it on a bridgeport and have him drill the holes in the intake for you. Keep the hole a little smaller than the injector bungs so you can ream out the hole a little so the bungs fit snug.
Take it to a friend to TIG weld the bugs in for you (Free in most cases if you know someone)
Take a die grinder and cut off the excess material left in the intake port and make sure you leave it flush with the roof of the intake port
Then take it back to the machinist and let him check the surface for straightness, when welding, you might have to get the intake milled a tiny bit to make sure its still flat
anything else ?
Old Aug 14, 2002 | 01:01 PM
z28kid93's Avatar
Post
hahha, plenty....
wow, it's a lot less than i thought. I was picturing like $1000 or something. Anyways, for your TB, you had said you were using a ford TB. Is it a mustang one? are you using the EGR spacer as well or is it just the TB? How are you gonna run your air intake tubing? How you doing throttle cable?
Thanks again.
Chris
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
