May have ported exhaust ports too much? Head Porters Inside!
Old Mar 5, 2004 | 09:35 PM
Muskys SS's Avatar
Question May have ported exhaust ports too much? Head Porters Inside!
I'm porting a set of LT1 heads myself and came across a topic that said not to match the exhaust port with the gasket, but I've already done it.. I didn't make any holes or anything, I'm talking strictly from a performance stand point. I heard that if you make the exhaust ports too big you lose power because the velocity of the exhaust gasses will be too slow and there isn't enough back pressure. I matched my exhaust port to almost the same size as a felpro 1406 gasket. The port still isn't as big as the 1 3/4" primaries of my AS&M headers, so will I be alright???? Any info would be greatly appreciated
Thanx!!!
Old Mar 6, 2004 | 12:01 AM
MaxRaceSoftware's Avatar
you should be ok
to be safer next time ...don't make exhaust port bigger than Exhaust valve's OD
Old Mar 6, 2004 | 08:54 AM
LameRandomName's Avatar
Some people theorize, and I happen to agree, that having your exhaust port be slightly smaller than the opening in your header, provides some small amount of anti-reversion protection.
But I agree with Max...
I don't think you bought yourself any problems by gasket matching.
Old Mar 6, 2004 | 08:36 PM
Muskys SS's Avatar
yeah. I guess there's not much I can do accept try it out. I've only done one head so far. Should I do the other head the same way I did this one or should I make the ports smaller???
Old Mar 6, 2004 | 10:30 PM
n20ta2's Avatar
I opened mine up to the same gasket and it makes power,just ran a 12.03 with stock valves and cc305 .
Old Mar 7, 2004 | 02:55 AM
Muskys SS's Avatar
That's reassuring.. Nice #'s!! I hope mine can do that
Old Mar 7, 2004 | 08:20 AM
Well certainly you'd want the two heads as well matched as possible.
Old Mar 7, 2004 | 07:57 PM
arnie's Avatar
The main concern here, is not permitting any mismatch of components (exhaust plumbing or gasket) when assembling. Because is is very possible, actually probable, to not bolt up components exactly centered, it becomes cheap insurance, to have anything assembled to heads, larger than the ports, by amount of possible mismatch, to be safe. As far as anti reversionary notions, sorry, takes more than a 1/32" to matter.
Off topic, but a good comparo; the very reason, bolting a 52 mm. TB to an oem intake manifold, is not a good idea.
Old Mar 7, 2004 | 10:42 PM
arnie's Avatar
Can you krazy glue the gasket...
As long as a satisfactory seal is not compromised, let necessity be the mother of invention. Or, improvise, and adapt.
Old Mar 7, 2004 | 11:01 PM
Muskys SS's Avatar
Yeah I see what you're saying.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
