Rockers gain and hp?
Old Mar 2, 2004 | 11:05 PM
Killaz's Avatar
Question Rockers gain and hp?
I was reading in a chevy mag. They added rockers on a 99vet LS1 and got some HP out of it. Has anyone done this? If So what were the gains?
Old Mar 2, 2004 | 11:17 PM
SSpdDmon's Avatar
I haven't done it....yet. I've been reading about 15~20 hp gains by upgrading to a full roller rocker with an increased ratio (1.7 to 1.85).
Old Mar 2, 2004 | 11:24 PM
Killaz's Avatar
wow, and it seems so easy. Correct me if im wrong. Throw them on tighten them down to 11ft/lbs and go.
Old Mar 3, 2004 | 01:21 AM
SSpdDmon's Avatar
Well...if you change the ratio, you're gonna need new springs. Plus, I think the correct torque is 24 ft/lbs. Other than that, it should be relatively straight forward.
Old Mar 3, 2004 | 07:07 AM
teke184's Avatar
yeah you need new springs, the stock springs are all but maxed out on lift.
max lift on stock springs is .525" but if you upgrade to 02 ls6 springs the lift is up to .600"
some info i found while researching a while ago:
www.thunderracing.com has yella terra 1.8 rockers for $500. combo motorsports has a comp cam kit with the 1.85 rockers (or 1.75 i think), springs and retainers for $550
Old Mar 3, 2004 | 08:25 AM
CrippleFightin's Avatar
Check out Cmotorsports.com, they usually have great deals on valvetrain stuff.
Old Mar 3, 2004 | 09:06 AM
CODY BEHNKE's Avatar
Besides the fact that they don't include springs how do the SLP rockers stack up against the others?
Old Mar 3, 2004 | 10:42 AM
teke184's Avatar
comp cams rockers are full roller...the SLP ones are only roller on the fulcrum not the tip....
take that as you will
Old Mar 5, 2004 | 01:46 AM
Zerocool's Avatar
hmm
Old Mar 5, 2004 | 01:59 PM
LT-14me's Avatar
you can get comp cams roller rockers for 300 bucks, not includeing springs, thats not bad at all when it adds 25 hp
Old Mar 5, 2004 | 09:44 PM
mrr23's Avatar
http://vincihighperformance.com/fbodyls1.html click the engine icon on the left. they have a 1.86 full roller rocker package for $699.00 includes rockers, jam nuts, screw in studs, and pushrods. you can also get the dual springs.
Old Mar 10, 2004 | 03:19 PM
SLPZ28's Avatar
I was lead to believe that with the comp cam I have now 224/228 with a 581/589 lift that I could not run roller rockers? Now was that due to the valve cover height?
Old Mar 10, 2004 | 05:53 PM
mrr23's Avatar
roller rockers will fit under the covers. going to a larger ratio may cause retainer to guide clearance issues. or coil bind. you can call www.vincihighperformance.com or www.compcams.com to clear it up.
Old Mar 10, 2004 | 10:04 PM
tbyrne's Avatar
The SLP 1.85 rockers are good for a 15-20hp gain. They have one package that is just rockers and two others that include springs, retainers ect... This is simular to doing a mild cam swap without going inside the motor. You can save 10% off these and most other SLP products during our sale that runs through Sunday.
Old Mar 10, 2004 | 10:58 PM
LT-14me's Avatar
what exactly is needed to run roller rockers? I know i will need new springs...and possibly rods? Not exactly sure what is required?
