'97 pcm in a '94 z28
Old Aug 22, 2002 | 11:47 AM
bigkidd's Avatar
Post '97 pcm in a '94 z28
i have a '94 z28 with a few mods.i recently came across a pcm from a '97 wrecked state police car that had the pursuit pkg in it.i put this in my '94 and seems to work fine but was wondering if anyone knows if this may cause any problems and what the differnce is between a "police package" and a normal z28.
Old Aug 22, 2002 | 12:16 PM
Hal Fisher's Avatar
Post
I don't think they gave it any special engine tune. Might have different gearing, is it shifting funny or at odd times?
Also strange the pcm is giving a code because your car doesn't have the back two sensors.
You know you can do a search on www.car-parts.com. They have a ton of odb1 pcms for under $50.
Hal
Old Aug 22, 2002 | 02:13 PM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Post
I don't know how it works- 96/97 have crank sensor. Put the OBDI back in, but a cable and TunerCat and do it the right way
KYLE-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marimecorps.com
Old Aug 22, 2002 | 02:17 PM
Hal Fisher's Avatar
Post
Kyle, it can't be that different or else an odb1 wouldn't work in 96/97 odb2.
Both probably have a sensor on the same wire that gives the same reading, their just in different places.
Hal
[This message has been edited by Hal Fisher (edited August 22, 2002).]
Old Aug 22, 2002 | 09:06 PM
bigkidd's Avatar
Post
thank you for your input.i think i will take it out and put my orginal back in and reprogram it.
thanks again...
Old Aug 23, 2002 | 08:06 AM
dayusmc's Avatar
Post
Hal- Just looked at the pinouts of both cars. The OBDII has a lot more wires- thats why I can't figure out how it works- There is nothing in the crank trigger wires on the OBDII. SO it doesn't get a signal, Just wondering how the OBDII ecm works without having all the sensers. It obviously works if his car ran. but I wonder if it worked the right way.
KYLE-SERGEANT USMC
Old Aug 23, 2002 | 09:18 AM
bigkidd's Avatar
Post
it does seem to shift sooner than my other pcm due to different gears.i did have it checked at a local gm dealer and we were unable to communicate with the pcm other than reading the vin# out of it.we could read all other sensors but not with the pcm.so its probably not working right.but my car is running.i will be putting my orginal back in and just reprogamming it.
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
