? For those with Trans Performance button in TA
Old Aug 19, 2002 | 07:28 PM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Question ? For those with Trans Performance button in TA
Well I need some Help(Again) I have just bought a Stock Trans performance button (the one in the center consoul of a 95 TA) I already added the wires to my computer for the button. But now I need to know where the wires on the button go to. The wire colors on the button are Black/White stripe, Brown, Light Blue, Dark Blue, and gray. Can anyone tell me what wire is what. I know one of them is a ground and one might be parking lights not sure. Thanks for any Help.
KYLE-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marimecorps.com
Old Aug 21, 2002 | 08:56 PM
stevil's Avatar
Post
This link doesn't look too helpful.
http://home.tampabay.rr.com/jayz28/tranperformance.htm
And this link used to have all the info, but its gone now.
http://members.aol.com/_ht_a/chipsbyal/trans/index.html
Light blue should go to the PCM
Gray should be the power for the light on the switch
Black/white should be the ground, for the light
That leaves brown and dark blue, which I can't find any info on. A guess would be that one of them is a ground for the switch... what the other is for, not sure.
What I'm curious about is how this is going to work on your 97? Got a 94-95 PCM. Or those wires you added do something?
Good luck
Steve · FormulaV8.com · 1994 Formula · A4 · 3.23
13.45 @ 102.5 MPH w/ 1.9 60' | 267 rwhp | 307 tq/lbs | 3535 lbs
"I know for a fact he is NOT an Easter bunny"
Old Aug 21, 2002 | 11:09 PM
dayusmc's Avatar
Post
I have a OBDI 94-95, in my car. But believe it or not it works on some OBDII cars as well. I put a switch in my friends 96(OBDII) and it works great. The tables are in the OBDII, but sometimes they are have the same values as the normal mode. If you have LT1edit for OBDII you can change the values. Bottom line- Some OBDII cars have the Performance values in them amd some don't. It must depend on when exactly the computer was made. I also posted this same post in the LT1 section and shoebox responded with the wire colors, so if anyone needs the colors and where they go look in the LT1 section. Thanks again for responding!!
KYLE-SERGEANT USMC
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
