How to lower BLMs?
Old Aug 12, 2002 | 09:49 PM
Ed_H's Avatar
Angry How to lower BLMs?
What's the best way to reduce my BLMs at part throttle / cruise? I'm seeing ~130-134 on both sides and am targeting a 124-128. I have no detectable exhaust or vacuum leaks.
Should I reduce the injector size, or increase the MAF table values? I know both will work, but I need input about the 'best' option if there is one. Thanks in advance.
Old Aug 13, 2002 | 10:01 AM
Hal Fisher's Avatar
Post
Either of those may help. I would try adjusting down the injector size like you stated first.
Hal
Old Aug 14, 2002 | 03:04 PM
Dr.Mudge's Avatar
Post
If you play with the injector size you will change the BLMs for the entire RPM range that you will see, so if you were fine in other areas like WOT then you now have to fix that as well.
Richen it up in the RPM ranges that are showing above 128...
Old Aug 14, 2002 | 05:48 PM
gb95zconv's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Ed_H:
[B]What's the best way to reduce my BLMs at part throttle / cruise? I'm seeing ~130-134 on both sides and am targeting a 124-128B]</font>
I wouldnt worry about it if your that close to 128.....Sure you can change the inj constant and drop the BLMs down but you will effect other cells at the same time. Whats the difference anyway in the pcm correcting up a small percentage or down a small percentage...its still correcting as it well should. If you worried about the pcm holding on to those 130+ values when you go WOT just use the BLM Locker program to lock the BLMs at 128 at WOT. Quit splittn hairs and go have some fun IMO.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
