Modified A4 users, need tranny help
Old Jul 29, 2002 | 11:13 AM
96z's Avatar
96z
Post Modified A4 users, need tranny help
I went to the track recently for the first time and ran a 12.7 at a 108 mph. Ive dynoed at 350 rwhp so my mph seems to be a little down. The car has been dynotuned so all the power is there. The problem is the tune has the bone stock tranny tables. These obviously need to be changed but I have no idea what to change and how much, etc.
Would anyone be able to give me a hand?
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
Old Jul 30, 2002 | 07:02 PM
MichiganSkip's Avatar
Post
What do you think your tranny should be doing? Shifting sooner, later, firmer or softer? I will tell you what I know. Most people don't talk tranny stuff on here for some reason but I will share what I know!
Michigan Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
Old Jul 30, 2002 | 09:32 PM
96z's Avatar
96z
Post
More or less my WOT shift MPH and shift RPM. Tranny could also shift a little harder although I already have a shift kit.
Anyone???
96 black Z28 A4
The Z
Old Jul 30, 2002 | 10:20 PM
Luna's Avatar
Post
What converter?
Old Jul 31, 2002 | 08:01 AM
Post
If you have LT1edit or TunerCat, you can change the WOT shift rpm/mph section to change the shift points. You can also change the shift firmness by editting the pressure tables. Do you have the software? That's the first thing you need.
Skip
BMR SFC,LCA,STB
Old Jul 31, 2002 | 08:01 PM
96z's Avatar
96z
Post
Yep got the software just dont know what numbers to put in.
2800 stall and 3.42 gears.
As of right now they are
1-2 28
2-3 59
3-4 110
Hot shift MPH same as HOT MPH
Normal and HOT shift RPM 5700
Keep the reply's coming guys.
Old Aug 1, 2002 | 09:11 AM
OneFlyn95z28's Avatar
Cool
what have you done to the motor? Where do you wnat it to shift?
The reason many do not talk A4 here is many have M6 or other trans and do not care or help.
A friend and I came up with the A$ no shift fix and I wrote the LT1 edit trans section you see on line. Go check it out there is some good info there
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
Old Aug 2, 2002 | 09:38 AM
96z's Avatar
96z
Post
Quick run down of mods...
GTP stage II heads, GTP 226/230 cam, hooker LTs, 58mm TB, cutout, 2800 stall, gears, CAI..all bolt ons possible, stock MAF, sensors etc.
The cam makes power up to 6200 RPMs and I obviously want the car to go as fast as possible.
Fred LT1 first pointed me in this direction based on his success of raising the shift RPM and MPH.
In the upper RPMs my car feels like it pulls half *** and it ended up being that my car shifts way before it makes all its power.
Ill make the WOT shift RPM 6200 I just dont know what would be good numbers for the MPH.
96 black Z28 A4
The Z
Old Aug 2, 2002 | 09:41 AM
96z's Avatar
96z
Post
<font face="Verdana, Arial" size="2">Originally posted by OneFlyn95z28:
</font>
Sorry if Im asking the obvious but where is this LT1 edit trans section?
Old Aug 3, 2002 | 05:55 AM
Post
http://www3.baylor.edu/~Christopher_...ht/LT1Edit.htm
This is what he is refering to. Lots of good info. There is an Automatic trans section there.
Skip
Old Aug 4, 2002 | 10:28 AM
96z's Avatar
96z
Post
Thanks, Ill have to check that out.
Old Aug 4, 2002 | 08:10 PM
Ryan94ZA4's Avatar
Post
I am interested in the trans pressure tables. I want to get rid of the slide bump shift into second and firm up the 2-3 shift. I need to know what is acceptable for trans line pressure. I know my reverse manual 700R4 runs between 125 and 150 psi of pressure but I am not familiar with safe operating pressures on the 4L60E.
I'd appreciate any help any one can give so I know my trans will live once I add the supercharger. On top of modding the pressure and shift tables, I will be upgrading the trans a little, too.
Ryan
1994 Z28 A4, Vortech, Borla with EBorla, TPIS 52 mm TB, Hooker shorties, Electromotive SDI, LS1 brakes, AAM 3.42 rear, more.
Victor Lamb
Aug 26, 2017 02:52 PM
BigWil
Mar 29, 2015 12:24 PM
Jlo
Feb 3, 2015 09:41 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
