Wide band o2 sensor kits
Old Feb 26, 2004 | 04:25 AM
lt4 fd's Avatar
I have seen some at machv.com and one other place I cannot remember off hand but is there a particular one that is better or anyone prefers for any reason? Just trying to make the most out of the software I have without running up on a dyno all the time and so I can tune my open loop program more accurately....
Old Feb 26, 2004 | 05:27 AM
BlackDog's Avatar
These 2 pages should help you in your quest.
http://performanceworks1.com/pcm_tuning_sites.htm
http://performanceworks1.com/computers.htm
Old Feb 26, 2004 | 07:50 AM
rskrause's Avatar
Moderator
Check out the Innovate Wide Band at www.kennedysdynotune.com I have one and like it.
Rich Krause
Old Feb 26, 2004 | 08:27 AM
dmoss69's Avatar
The dyno that I went to had a sensor that looked like a stick, that they stuck up into my exhaust instead of a regular looking O2 sensor.
I'd want something of this nature so I could use it on all of my cars and not have to put O2 bungs on everything that I work on.
Of course, I'l probably have to dump the checking account to do so.
What do yall think?
D Moss
Old Feb 27, 2004 | 05:37 PM
lt4 fd's Avatar
Thank you very much guys!
Old May 8, 2004 | 07:25 PM
Taffy's Avatar
What do yall think?
D Moss
www.innovatemotorsports.com has what you want. But I think you said that you already had one!
Old May 8, 2004 | 07:51 PM
patSS/00's Avatar
Tech Edge (wbo2.com) has a DIY kit which comes to around $160 U.S. last I checked (they're in Australia), plus the sensor will be around $40. Looks like it requires a fair amount of soldering. That's the one I'm thinking of getting. Here's another one that looks interesting:
http://www.zeitronix.com/Products/zt2/zt2.htm
Old May 9, 2004 | 05:03 PM
Dan K's Avatar
I bought the Innovate wideband from Taffy and couldn't be happier.
I also bought the optional exhaust clamp that allows me to use it on all of the "other" cars that I tune. Works like a champ.
Old May 9, 2004 | 07:04 PM
lt4 fd's Avatar
Now this is sort of confusing me, but on the accesories page of the innovative one the first item on the list, does that somehow log the rpm along side the afr? That would be helpful...
Old May 10, 2004 | 02:08 PM
Taffy's Avatar
Glad ya liked it! Everyone so far has liked this kit. The only way they could make it better is to give it away!
Old May 10, 2004 | 02:12 PM
Taffy's Avatar
If you get just the LM-1 kit, you can only datalog the Wide Band AFR. This is logged internally in the box for up to 44 minutes. You then download the info to your computer via the supplied software for reading.
If you get the RPM Cable (Aux Input #2), you can now datalog the RPM and 5 other inputs. You cna datalog all the inputs (total of 7) and compare them on the Software. I suggest to get the RPM Cable so that you can reference the RPM to the AFR when datalogging.
Old May 10, 2004 | 02:47 PM
lt4 fd's Avatar
OH wow that would be awesome, MAP would help too so if you log up to 7 that would be awesome... Ill have to defenitely put this sucker on my wish list...
Old May 12, 2004 | 09:23 PM
Taffy's Avatar
You can log MAP with the RPM cable (Aux #2), but you need to supply the MAP sensor.
Innovate is releasing the AUX #3 cable that logs MAP. MAP is included in the cable.
Old May 13, 2004 | 01:11 AM
Eff's Avatar
Eff
What do yall think?
D Moss
They are not all that accurate. thats why most pro shops stick with wide band
Old May 13, 2004 | 01:19 AM
dmoss69's Avatar
I just ordered my LM-1 today with the exhaust clamp! Oh that checking account is feeling it.
D Moss
