lowering
Old Feb 26, 2004 | 12:36 AM
2000camarostud's Avatar
lowering
Alright guys...need your advice. I'm thinkin about lowerin my car here as soon as my tax returns arrive hehe. Thing is, is that when i lower the car, that black baffle on the bottom to scoop air up to the radiator will scrape on EVERYTHING as it does very often as it is now, with stock suspension. What have you guys who already have lowered your car done? did u just remove it or what? please let me know. thanks.
Old Feb 26, 2004 | 03:48 AM
chevyman502bb's Avatar
DO NOT LOWER IT?~?~?~?~?~?~?!?!?!?!?!?!!?
i dotn have a lowerd f-bod, but i have a slammed S10 (4 sale, buy i!)....i love my low rider S dime, but i will never own another lowerd car/truck.....rides like hell, depending on your state laws u can only go so low, ground clearance is a bitch, i gotta go 3 mph over a speed bump
doesnt sound like much, but heres a tip....research ur state laws for ride height, try to drive a lowerd car b4 u lower yours to feel the diff
Old Feb 26, 2004 | 10:17 AM
J0HN D's Avatar
I lowered mine a little over 1.75" with Eibach v8 springs and Koni SA shocks. I put the springs on the lower perch on the fronts, and trimmed 1/2" off the top of the rubber isolater on the rears.
That black piece is flexible, so it will be ok. Don't remove it because it will reduce the air flow through the radiator.
I do have to go slowly over speed bumps, some I have to avoid entirely.
The front rides good, the back is a little too stiff. But I wanted better (stiffer) springs for autocrossing.
Old Feb 26, 2004 | 12:22 PM
would it be ok to trim the black plastic piece a bit then? maybe hack off an inch or so? do you scrape it alot going over speed bumps and leaving parking lots? because as it is now, i do quite often...but i think lowering my car would make it look bad *** and would make it corner better than it already does stock.
Old Feb 26, 2004 | 12:45 PM
ImportKILLER's Avatar
Most people I know that lowered just removed it.
Scrapes bad enough on a stock car.
Old Feb 26, 2004 | 01:16 PM
2Poor4Z's Avatar
well i have a wings west w-type kit on my 97.. it comes with a new, even bigger, "black thing" mine scrapes everywhere and its not lowered and even riding on 18's... but.. i am planning to do air ride on mine.. and when i do to get the drop i want this thing will need to go.. i have put just the stock back on and it raised the engine temp 20 degrees roughly.. should have the ssame affect when just removing the stock one without ground effects.. i am planning on putting the stock one back in and then putting in a 160 thermo to compensate for the extra 20 degrees.. maybe u should try that
Old Feb 26, 2004 | 01:53 PM
camaroguyo's Avatar
mine is lowered 1.5inch i put on the black wind deflector that came with my wings west kit, it rubbed on everything then broke. i went to a dealership and bought one, this one was alot smaller and doesnt rub on too much stuff, u kinda get used to it, and lowering is worth it!! looks bad azz
Old Feb 26, 2004 | 04:49 PM
J0HN D's Avatar
You might be able to trim some off, but I don't think it's much more than an inch as it is...
I don't scrape the front over speed bumps, but I do scrape the cat and the exhaust pipe.
The ground effects on the sides are what I worry about scraping now. (but they haven't yet).
Old Mar 1, 2004 | 12:06 PM
2Poor4Z's Avatar
haha.. groudn effects.. yea wings west kit and 18's not lowered.. you should see the bottom of my groudn effetcs all the way aroudn lol.. looks like hell.. thank god its on the bottom
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
