'95 OBDII problem
Old Feb 24, 2004 | 06:29 PM
Jason Pittman's Avatar
'95 OBDII problem
I have a '95 with an OBDII. I bought a scantool and plugged it in but it just read that there was an error. I hooked it up to my friends '99 LS-1 which is also an OBDII and the thing worked. I have heard someone call the '95 the bastard year because it is the first year of the OBDII but the same engine and it doesn't belong and has a lot of problems, has anyone else encountered this problem or has anyone heard about this?
Old Feb 24, 2004 | 06:59 PM
moparman's Avatar
I really hate to break the news to you, but the '95 is OBDI with an OBDII style connector. You're not the first one to think it is OBDII.
Old Feb 24, 2004 | 09:57 PM
Tails's Avatar
Yep sounds like an OBDI with and OBDII connector. To be sure check this site out and compare the ones there to the one you have:
http://www.mastach.com/index.php?module=aldlconn&l=en
Laters
Tails
Old Feb 25, 2004 | 04:14 PM
Greg_pl's Avatar
They're right, although you have 16 pin connector (like OBDII) it's still a OBDI car. '95 is a perfect year for an fbody, still an easy OBDI (cheaper to tune) and a vented opti.
Old Apr 17, 2004 | 06:20 PM
350350's Avatar
I was under the understanding that '95 was a switchover year, and that they went from OBDI to OBDII somewhere late in '95 when they were ready, meaning that there were some '95 OBDII cars.
I'm in the same boat. I have a '95 car that I thought was OBDI but am now confused beyond all reason... It's definitely an OBDII connector, but How the hail do you get the codes out of it if there isn't an OBDI scanner with an OBDII connector???
Old Apr 17, 2004 | 10:11 PM
tjwong's Avatar
Its definitely a OBD1 computer with a OBD2 connector. There were no OBD2 PCMs in any 1995 car. There were however plenty of OBD2 diagnostic connectors in that year.
Old Apr 18, 2004 | 11:28 AM
350350's Avatar
OK, now how do I get the codes out of it??? I read through the GM Service manual and the way the connections are mapped in the OBDII style connector, I don't see any way to use a paper clip like you could with the old OBDI connector...
Old Apr 18, 2004 | 09:46 PM
97Z-M6's Avatar
NO THE PAPERCLIP WILL NOT WORK YOU HAVE TO HAVE A SCANNER sorry about the caps
79RS
Mar 24, 2015 09:30 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
aj2494
Mar 12, 2015 10:17 PM
383TransAm
Parts Wanted
Feb 15, 2015 05:05 PM
InfernalVortex
Jan 17, 2015 09:35 AM
