? on Auto X-ray scanner results.
Old Feb 23, 2004 | 10:26 PM
BLK96Z28's Avatar
Question ? on Auto X-ray scanner results.
When i plug my Auto X-ray scanner into my 96 Z28, it reads "Ignition Timing Adv." around -20 degrees at idle and on throttle moves up to -46 degrees. When I compare and plug into my friends 97 SS, it doesn't put the - (minus) sign in front of the number of degrees.
Example:
-18 Degrees for the 96 Z28 at idle
18 Degrees for the 97 SS at idle
The engines are identical and both OBD2. Why the difference?
The 97 has a Jet Stage 2 chip if that helps any (doubt it)
Old Feb 24, 2004 | 06:58 AM
moparman's Avatar
It doesn't matter if it has the - or not.
Nayr
Mar 3, 2023 08:34 PM
plattted
9
Sep 20, 2015 11:23 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
scottcba1
Sep 8, 2015 09:52 AM
tdigger9899
Sep 7, 2015 10:56 AM
