do 3:73 give you better pull on higher speeds too?
Old Feb 23, 2004 | 01:35 PM
SiDeWaYZz28's Avatar
Question do 3:73 give you better pull on higher speeds too?
hey everybody i was wondering if they give me better pull up top as well as low end...i have 323 and ive been thinking about doing the swap....thank you
Old Feb 23, 2004 | 01:36 PM
AxeGrinder30thZ's Avatar
They should.
Old Feb 23, 2004 | 01:37 PM
n20ta2's Avatar
yes
Old Feb 23, 2004 | 01:44 PM
Z28BICOL's Avatar
At low end my Z gets a good pull, but not at the high end. I miss my 3:23, specially when I overtake at 60 and up.
Old Feb 23, 2004 | 01:52 PM
ok so i shouldnt go with 373 then because i want good pull on the freeway
Old Feb 23, 2004 | 02:07 PM
Johnnynsac's Avatar
I thought 373 would give you a good pull in every gear, even on the freeway??
You might go faster with 273 but 373 would get you to your destination quicker, right??
Old Feb 23, 2004 | 02:08 PM
Jay-Roll's Avatar
If you want good pull up top and better acceleration down low I'd recommend 3.42's. Unfortunately you probably won't see much of a performance increase if your going from 3.23's. They will give you a little extra in both areas though. Your gas mileage probably won't change much either, if at all. With your current gears though I'd recommend a different mod. I'd say get a good stall converter. The cost will be about the same and you'll get a lot better times out of your car without hurting your top end at all. Since you already have a shift kit it would be an easy install and I bet you'd be very very happy. I'd guess you'd have a good flash when passing apon stomping the gas pedal too. It will wake your car up like no other. Definately get a tranny cooler though. JMO
Old Feb 23, 2004 | 02:15 PM
ok thanks for the input
Old Feb 23, 2004 | 02:41 PM
drewstealth's Avatar
3.73 would give you higher pull up top as apposed to 3.42's would. They give you more pull in all gears. But the 3.73's would hurt your top speed some compared to the 3.42's. For instance if you had the same car with 4.10's and the same car with 3.42's side by side and both cars punched it the car with the 4.10's would pull from the car with 3.42's. The car with the 3.42 would be able to go to a higher top speed though as long as the wind resistance wasn't a factor.
Old Feb 23, 2004 | 02:49 PM
transamdude95's Avatar
I've got a question about shift points. With my 2.73's, I shift from 1st-2nd at 45mph and 2nd-3rd, 90mph... haven't gone further lol. If I went to 3.73's, how much of a change would I see in shift points? Big drop in gas mileage also?
Steve
Old Feb 23, 2004 | 03:52 PM
Zigroid's Avatar
I too am switching to 3.73s (just got them today!!) and was curious about the shift points as well. I used this site to figure the following out based on the car's redline.
with 2.73's
1st gear
5700 rpm 52 mph
2nd gear
3000 rpm 52 mph
5700 rpm 98 mph
3rd gear
3500 rpm 98 mph
5700 rpm 159 mph
4th gear
4000 rpm 159 mph
5700 rpm 228 mph (I hit 228 mph once, really!)
with 3.73's
1st gear
5700 rpm 38 mph
2nd gear
3000 rpm 38 mph
5700 rpm 72 mph
3rd gear
3500 rpm 72 mph
5700 rpm 117 mph
4th gear
4000 rpm 117 mph
5700 rpm 167 mph
these should basically be close to the shift points of the 2.73 A4 car vs a 3.73 A4 car.
Old Feb 23, 2004 | 04:18 PM
Johnnynsac's Avatar
Originally posted by Zigroid
I too am switching to 3.73s (just got them today!!) and was curious about the shift points as well. I used http://www.f-body.org/gears/]this site to figure the following out based on the car's redline.
with 2.73's
1st gear
5700 rpm 52 mph
2nd gear
3000 rpm 52 mph
5700 rpm 98 mph
3rd gear
3500 rpm 98 mph
5700 rpm 159 mph
4th gear
4000 rpm 159 mph
with 3.73's
1st gear
5700 rpm 38 mph
2nd gear
3000 rpm 38 mph
5700 rpm 72 mph
3rd gear
3500 rpm 72 mph
5700 rpm 117 mph
4th gear
4000 rpm 117 mph
5700 rpm 167 mph
Those numbers look a little off for the 373.
Old Feb 23, 2004 | 04:22 PM
Zigroid's Avatar
well I used the one calculator off the f-body.org site. I don't know how accurate it is but you can try for yourself here:
Old Feb 23, 2004 | 06:21 PM
stereomandan's Avatar
You might want to check out this Excel spreadsheet that I made.
Gears mainly help in 1st gear. You can see why from the charts in the Excel file. They help VERY little at higher speeds, as you can see from the chart.
I charted rwtq vs. speed. This is for a stock LT1, going WOT, shifting at redline(5700 rpm).
Right Click, Save As
Dan
Old Feb 23, 2004 | 06:55 PM
JJJ93z's Avatar
Dan
awesome job on the spreadsheet! very informative
