Should I buy this kit?
Old Feb 22, 2004 | 10:25 AM
allnet777's Avatar
A kid in my school is selling a NX 50-150 Wet Kit for cheap. I do not know much about nitrous as of yet and I dont wanna get ripped off, so im going to bring a more knowledgeable friend on the topic. It is a universal kit, not the efi 50 - 150 I thought it was. Is there alot of differences between the two? Should I not purchase the universal kit? Besides this kit all I will need would be colder plugs and a window switch to run safely correct? Thanks to all in advance.
Old Feb 23, 2004 | 04:17 AM
HeavyChevySS's Avatar
If you are new to nitrous, i would suggest getting a dry kit cause they are the easiest to install and are quite potent under 175HP range.
To run safely, I would also suggest a Hobbs switch or a Fuel Pressure Safety Switch. Start with a small shot and work your way up from there. Enjoy!
Old Feb 23, 2004 | 09:50 PM
allnet777's Avatar
This kit is wet and I dont have to worry about the install. Thank you though for your insight, I will check up on the switches. Does anyone else have some knowledge pertaining to the questions above?
Old Feb 24, 2004 | 04:58 PM
allnet777's Avatar
Anyone?
LeftoverChinese
Jan 14, 2024 03:03 PM
blac94Z
29
Mar 25, 2015 04:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
