Rubber brake line...rounded the bolt!!
Old Feb 16, 2004 | 05:31 PM
xxsaint69x's Avatar
Angry Rubber brake line...rounded the bolt!!
Well i am in process of taking of my old brakes to put some baer brakes. The passanger side came of nicely, but same cant be said for the driver side!! I rounded the bolt that connects the rubber line to the metal one. How should i go about removing it? The connecor has to be replaced as well once i take it off.....What will be the best way to fix this mess?
Marcin
Old Feb 16, 2004 | 05:36 PM
Robs97Z28's Avatar
I guess the best way would be to use a tubing cutter and cut the metal line removing the bad fittiing. Then use a double flairing tool and put on a new connector.
If it is a flare nut, you should always use a flare nut wrench, but even then sometimes you can get into trouble. If you are going to replace it, time to get out the vice-grips.
Old Feb 16, 2004 | 05:41 PM
Robs97Z28's Avatar
would just be easier to cut it off if you are going to replace it?
Old Feb 16, 2004 | 05:42 PM
93turboTA's Avatar
I agree 100%- always use a flare nut wrench I learned the hard way and now I have a set
Old Jan 31, 2006 | 01:45 PM
JeffK95Z's Avatar
Re: Rubber brake line...rounded the bolt!!
Hey guys,
i'm going to be doing brake lines on my LS1 upgrade soon and i'm wondering what size of flare nut wrench is needed for taking the lines off?
thx!!
jeff
Old Jan 31, 2006 | 04:03 PM
PLEASE don't post "brake" questions in "LT1/LT4 Engine Tech". Moving to Suspension, Chassis and Brakes.....
Old Jan 31, 2006 | 04:05 PM
JeffK95Z's Avatar
damn... sorry Injuneer
I jsut replied to a thread i had searched for... never really paid attention to where it was posted orginally...
Old Jan 31, 2006 | 04:30 PM
wrd1972's Avatar
What he said
Old Jan 31, 2006 | 04:59 PM
JeffK95Z's Avatar
Originally Posted by wrd1972
What he said
I know that... but i asked what SIZE of a flare nutwrench???
Old Jan 31, 2006 | 05:05 PM
Just get a set and then you can choose the one that fits.
Old Jan 31, 2006 | 05:14 PM
JeffK95Z's Avatar
hehe
the sets i see come in packs of 3... so i guess thats 6 tries for the right size. Not horrible odds i guess
Old Jan 31, 2006 | 05:54 PM
OBE1 95Z28's Avatar
I've had some success with reshaping the rounded fitting with a file. Flare wrench is the way to go. Also sometimes by slightly tightening the fitting first before loosening it can help to break them loose. As Shoebox stated, vice grips can save you if can't get it with a flare wrench.
Old Jan 31, 2006 | 10:15 PM
respectirocz's Avatar
hehe
well the brake line is 3/16ths, so its gonna be the smallest of the flare nut wrenches
the brings it down from 6 wrenches to 2, the smallest sae and the smallest metric
Old Feb 3, 2006 | 12:48 AM
Compstall's Avatar
Same thing happened to me 3 years ago and I HAD flare nut wrenches. Had to cut it off. Not even vice grips would get it off. The flare nuts are soft metal.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
