Torque Arm Mount For TH350???
Old Feb 8, 2004 | 05:13 PM
amc91z's Avatar
anyone have one so I can put a TH350 in my 91 z28?????
Thanks,
Adam
amc91z@team.camaroz28.com
Old Feb 8, 2004 | 11:40 PM
1SLOSBC's Avatar
new or used, go with the B&M kit. the husrt kit doesnt come with the proper piece to relocate the tranny mount.
goodl luck.
Old Feb 9, 2004 | 06:00 PM
amc91z's Avatar
So if I get the B&M kit can I use the stock 700r4 crossmember?
Thanks,
Adam
Old Feb 9, 2004 | 06:17 PM
1SLOSBC's Avatar
you can use the stock x member with the B&M. it comes with a huge 3/8" thick plate to move the tranny mount back to the stock location. the hurst does not come with this piece. less fabrication is required with the B&M.
the hurst includes a bracket for the throttle and some vacuum line, but its not worth the sacrifice, IMO i run a manual valve body, so those items were useless to me.
let me know if i can help.....
Old Feb 9, 2004 | 10:07 PM
amc91z's Avatar
Thanks for the help!!! I'll also be using a manual valve body so I wont need the vacuum line or the throttle piece! And the B&M stuff is cheaper Did you use a short or long tail shaft TH350?
Thanks,
Adam
Old Feb 9, 2004 | 10:14 PM
amc91z's Avatar
Just curious what convertor your running and if your car is N/A, blown, or n2o?
Thanks,
Adam
Old Feb 9, 2004 | 10:27 PM
1SLOSBC's Avatar
dont know if it matters, but i used a short tail without a problem. you will need a longer driveshaft.
i run a 10" PTC converter. im all motor right now, but will be spraying it by the end of the year.
7.50 1/8 mile at 90mph motor. bout an 11.4 in the 1/4. 3600# raceweight.
Jasonz28camaro
Jun 7, 2015 09:14 PM
KYWes
May 22, 2015 08:48 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
