Moser 12bolts......
Old Feb 8, 2004 | 02:17 AM
simple's Avatar
Moser 12bolts......
does anyone know if Moser 12bolts have c-clips standard?
if not what do they use?
i'm curious if mine has them or not and wanted to know if they even came with them before i take off the cover to see for myself.
my rearend has LS1 brakes, does the LS1 backing plate act as a c-clip eliminator?
thanks
Steve
Old Feb 8, 2004 | 08:34 AM
funina91ss's Avatar
the bearings on the axles hold it in place, along with the backing plates. No C-clips
Old Feb 8, 2004 | 06:16 PM
simple's Avatar
thank you sir
Old Feb 9, 2004 | 10:47 AM
You might want to check your invoice. From the Moser Engineering 12-bolt listing:
....Consumers also have the choice of axles with pressed on bearings, or OEM style c-clip axles with c-clip retention.
Old Feb 9, 2004 | 12:00 PM
simple's Avatar
ok so if i have pressed on bearings then i do not have c-clips?
i traded rearends (4channel to 3channel swap) and i remember the guy saying he had to have the bearings pressed on over the backing plates
Old Feb 9, 2004 | 12:06 PM
simple's Avatar
QTY PART NO. DESCRIPTION RATE AMOUNT
1 DS The following items are being shipped directly from the manufacturer: (Please allow 10-14 working days for delivery) 0.00
1 96-12B Moser F-body 12 Bolt Rear End, complete bolt-in with posi. Comes standard with 30 spline Eaton posi, Mosier Eng. Custom Axles, Pro-Street Gears, Pinion Yoke and Chrome Cover 2,020.00 2,020.00 T
1 MISC GEAR RATIO 4.10 0.00 0.00 T
1 96-ABS-3CH ABS setup for 3 channel 100.00 100.00 T
1 96-1350 Upgrade to 1350 yoke 35.00 35.00 T
1 96-TACOVER Upgrade from standard chrome cover to TA Performance Aluminum cover 135.00 135.00 T
1 MISC CRATE FEE 20.00 20.00 T
1 FC MOSER F-BODY 12 BOLT REAR END ARE SHIPPED TRUCK FREIGHT COLLECT DIRECTLY FROM THE MANUFACTURER. FREIGHT CHARGES MUST BE PAID TO THE TRUCKING COMPANY UPON RECEIPT.
2,310.00
OUT OF STATE SALES TAX...EXEMPT 0.0% 0.00
Total
$2,310.00
thats the e-mail order invoice from Thunder, no mention of c-clips, with or without....hmmmmm
you think there is a way to tell thru contacting either Moser or Thunder Racing
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
ddr698
Jan 9, 2015 10:05 AM
Shawn's Dad
West South Central
Sep 12, 2002 09:11 PM
Shawn's Dad
West South Central
Sep 1, 2002 08:32 AM
