...can the power steering pump eat fluid......
Old Feb 2, 2004 | 11:16 PM
WipeOutXXL's Avatar
I just filled it up, it was making a nasty sound and it was on empty, but there are no black marks on the driveway when I park it. So it dosn't seem to be leaking. The only other option could be that it's being eaten or it only leaks when the car is on driving on the highway. What do you guys think? I got a new pump in September when the crank broke in on the inside and they had to change it.
Old Feb 4, 2004 | 09:49 AM
cop_camaro's Avatar
Angry
Check your Coolant overflow tank!
Hope its not in there.
Old Feb 4, 2004 | 01:18 PM
ZZed's Avatar
There could be a leak in the boot, or the power steering cooler (if equipped). The would dump ps fluid in the coolant. My best guess would be that the system wasn't bled when the pump was changed. Air in the system gave it a false level reading. Over time it equalized, and the pump went dry. Add fluid, then bleed the system if you want. You need an adapter from GM (basically a plug with a hole in it) and a hand vacuum pump. Pump and check the level until the level doesn't change.
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
XtremeLt1
Sep 13, 2002 08:50 PM
