What cylinders run the leanest under boost?
Old Feb 1, 2004 | 10:54 PM
Serene's Avatar
I'm guessing 1 and 2 b/c of the fact the air is being force to the back of the intake?
Anyone have input? Looking for the leanest 2 cylinders under boost to put an egt gauge on.
Old Feb 2, 2004 | 12:09 AM
Ryan94ZA4's Avatar
From what I have seen, 7 and 8 run lean. Like you said, the air is forced to the back of the intake. This causes the back cylinders to get more air which makes the air fuel ratio lean. Typically, on a forced induction car, if you break pistons, it's either cylinder 7 or 8 or both of them.
Ryan
Old Feb 2, 2004 | 12:19 AM
Serene's Avatar
duh. i think i had a brain fart there. 7 and 8 sounds like a plan to me, anyone else?
Old Feb 2, 2004 | 12:34 AM
LukeZ28's Avatar
#7 plug always looks the most off
Old Feb 2, 2004 | 09:17 AM
sleeperz28's Avatar
7+8 typically blow out first thats why its a good idea to get your injectors flowed so you can throw the heavier ones in the back.
Old Aug 24, 2004 | 02:31 AM
Highlander's Avatar
Re: What cylinders run the leanest under boost?
that can be solved by adding a bit to the injector balance on the pcm
DirtyDaveW
Dec 1, 2016 05:37 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
JordonMusser
Jun 13, 2003 11:53 AM
