Parting out LT4 engine/tranny
Old Feb 1, 2004 | 11:21 AM
'95 LS1 Z28's Avatar
OK here it goes:
LT4 heads with Comp dual springs, retainers, & locks $1500
LT4 intake w/fuel rail & stock injectors$250
BBK 58mm TB $250
All engine sensors $200
GM Opti-Spark(not aftermarket) $200
K&N FIPK cold air system $125
PCM(programmed to run a 360cid w/LT4 top, CC306 cam, and PT3600 stall converter) $150
Full engine/tranny wiring harness $250
360 cid (bored 60 over) 4 bolt main iron block with pistons, rings, rods, crank, and oil pan, no cam $900
Comp Cams 306 cam 230/244 .510/.540 112lsa $200
Comp Cams Pro-Magnum 1.6 Roller Rockers $200
A/C compressor, lines, dryer, condensor (90k miles) $150
Alternator (from O'Reillys, 600 miles) $50
Power steering pump (90k miles) $50
Stock 4L60E Tranny w/stock converter (90k miles) $300 Sale Pending to M-MAN
Yank custom built PT3600 Converter (200 miles) $600 Sale Pending to 'apr97ramair'
B&M Supercooler for tranny (200 miles) $50 Sale Pending to 'apr97ramair'
EVERYTHING has less than 500 miles on it unless otherwise noted.
I would like to sell most of the big stuff first otherwise I may as well not sell it.
I will sell it ALL (fully assembled) for $4500.
Old Feb 1, 2004 | 02:38 PM
TEAL94Z28's Avatar
How big is the TB?
Old Feb 1, 2004 | 04:15 PM
Sorry, fixed. 58mm
Old Feb 2, 2004 | 09:27 AM
Mags94SS's Avatar
Interested in the block which is LT1 or LT4? Where are you located? Do you have any pictures of the block, if so can you email me at Marmendariz@suncoast-pt.com. Also what are the specs on the block, what crank, type of piston, etc.
Thanks,
Mag
Old Feb 2, 2004 | 05:47 PM
PM sent!
Old Feb 3, 2004 | 02:24 PM
M-MAN's Avatar
$ 250 for the tranny.
Old Feb 3, 2004 | 02:28 PM
4L60E
PM sent
Old Feb 3, 2004 | 03:10 PM
Mags94SS's Avatar
I'll pass on the engine.
Old Feb 5, 2004 | 06:05 AM
ttt
Old Feb 5, 2004 | 11:06 AM
DRAGRACR's Avatar
Motor
Is this a stock crank in this motor??
Old Feb 5, 2004 | 12:36 PM
FacelessZ's Avatar
Are the pro mags SA or NSA. If NSA, do you have the guide plates? Stock studs of 7/16?
Old Feb 5, 2004 | 04:50 PM
The crank is aftermarket but not forged. Stock size.
Explain SA and NSA....
Old Feb 5, 2004 | 04:52 PM
GT40MkI's Avatar
self align
or non self align
Old Feb 7, 2004 | 11:28 PM
ttt
I want to say self align. All parts that you need will come with them. I believe they are stock stud size for LT4 heads.
Old Feb 8, 2004 | 04:26 PM
TEAL94Z28's Avatar
Still have the converter?
