3.23 to 3.73 gears what else
Old Jan 28, 2004 | 08:15 PM
My 97 Z28's Avatar
A4 3.23 to 3.73 gears. What else do I need to do besides get the speedometer adjusted? I heard something about needing to change the shift points? IF so, what would I need to set the shift points get at?
Old Jan 28, 2004 | 09:05 PM
jchevy's Avatar
The shift points will probably need to be backed down a few mph for the 1-2 shift and also the 2-3. When i had my old auto. car i did it as a trial and error thing. Jus kept taking away mph with lt1_edit till i didnt bounce off the revlimiter anymore.
Old Jan 28, 2004 | 10:21 PM
My 97 Z28's Avatar
SO when you say a few MPH you mean like 2-3 mph? I heard if I sent my PCM to pcmforless and had them do it they would get it right. That true?
Old Jan 28, 2004 | 10:24 PM
jchevy's Avatar
Yeah, he probably knows what he is doing, you shouldnt have a problem if you send it him.
Old Jan 28, 2004 | 10:27 PM
My 97 Z28's Avatar
One more question off topic, how did your stainless works offroad pipe fit? I am looking into getting one.
Old Jan 28, 2004 | 10:47 PM
jchevy's Avatar
The fit was ok, but wasnt the best. I had to shorten two of the straight pieces about an inch in order to get it in and together. It comes in pieces with band clamps to hold it all together. Once i got it in i took it to an exhaust shop and had them weld it together, They also adjusted it a little bit so it fit up snug against the bottom of the car.
I would buy it again, i think it was worth the money.
Old Jan 29, 2004 | 10:24 AM
My 97 Z28's Avatar
I have a chance to buy a Hyperteh for $150 shipped. Worth the money?
Old Jan 29, 2004 | 10:29 AM
My Mighty White 95 Z28's Avatar
Smile
Well to answer your question about the hypertech, the reason I use the hypertech is turning on the fans early and also reprogram my car for the gears. If I had to do it again I should of just got my car programmed by a buddy of my or PCMFORLESS or MADWOLF. So I would hold off in buying that and just geting some mail order tune.
Old May 27, 2004 | 10:52 AM
Z06Z28's Avatar
My 97 chevy -
So how you liking them new gears? Tell me what you have noticed so I can get some ideas. I was thinking of going 3.73's as well since a cousin of mine is doing a buildup and is convincing me to do the same gear ratio but I wanted to peek in here first to get some feedback. Thanks...
Old May 27, 2004 | 11:29 AM
Red95M6Z28's Avatar
Nothing against hypertech but I think that a madwolf tune is far better for less money. He can adjust for gears and turn your fans on too.
Old May 27, 2004 | 03:48 PM
speed_demon24's Avatar
Spend the $150 and get a pcmforless.com tune. A hypertech won't give you any hp, if anything it will hurt a little. Think of it as a $150 fan switch...
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
blac94Z
29
Mar 25, 2015 04:21 PM
