Need help converting OBD1 PCM for OBD2 conversion
Old Jan 20, 2004 | 11:11 PM
jchevy's Avatar
I am doing an OBD2 convbersion on my 97 Z. I want to make it plug and play so i can go back to stock for emmissions. All i want to do is have to swap out the computers.
Through searches on this site i have figured out that the only thing i really need to do to the PCM is wire in a a 3.9k ohm resistor between ground and pin 22 of the blue connector.
Does this mean i take a the 3.9K resistor and ground out that pin with it to any ground on the car? Is this right, i dont really want to fry this computer. Any thing else than needs to be done?
Old Jan 22, 2004 | 11:56 AM
tjwong's Avatar
When you open your PCM up, on that same board is the grey colored connector. If you solder that resistor to the 22 of the blue connector then connect the other end to pin 32 of the gray colored connector that is a PCM ground. The gray colored connector is on the same circuit board that you are connecting the resistor to. Doing that you won't have to bring any wires out of the PCM. Or you can go to the nearest case ground on the circuit board. Be sure to properly insulate your resistor wiring.
Old Jan 22, 2004 | 12:29 PM
jchevy's Avatar
Thanks for your help, i think i understand it now.
Old Jan 22, 2004 | 03:49 PM
fireman's Avatar
This is for the knock sensor, right?
Old Jan 23, 2004 | 10:10 AM
tjwong's Avatar
Yes it is. The 96 and up PCM uses a KS with a 100k ohm shunt resistor while the earlier cars uses a 4k ohm resistor.
Old Jan 23, 2004 | 02:53 PM
Botch's Avatar
Is that all that is required to convert one for plug and play. What wattage resistor should I use? I am doing this also and I appreciate all of the information.
Thanks,
Botch
Old Jan 24, 2004 | 10:03 PM
tjwong's Avatar
1/8 watt is more than adequate for this.
Old Jan 25, 2004 | 12:32 PM
Botch's Avatar
Thanks. Done and it works!
Old Jan 25, 2004 | 01:17 PM
jchevy's Avatar
OK, stupid question time...How do i tell which pins are 22 and 32? Do they go in a certain order or what?
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
nikolt1
Feb 27, 2015 09:10 PM
